Old 11-30-2010, 09:57 AM   #17
insite
ok, so what's left?
1. cut 3/8" spacers to raise transmission above suspension crossmember
2. install suspension bits, bumper, etc
3. address apparent oil leak from cylinder 1 spark plug tube
4. drivability
this last one looks like we may have a small issue. i fired it up last night. the good news is that it started right up. the bad news is that i have a lumpy idle and a lot of smoke. it SEEMS like i have no fire in one of the cylinders. i plan on hooking up a code reader tomorrow to see what, if anything, has tripped. i'm hoping it's something simple, like a mis-connected spark plug wire or a poorly engaged coil pack.
i also seem to have a leaky spark plug tube. it's new, and so are the seals, so perhaps it's just not seated properly.....
i got a little excited toward start-up & took fewer photos than i had planned to. i will snap some more shots of the completed installation when i do some more work. until next time.......
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
