Originally Posted by J60SON
Maurice,
Fantastic, I did what you said and low and behold one of the flat contact strips solder had come away from its point. I manually held the 2 points and it worked.
I will now aquire a small soldering iron and repair accordingly.
Many thanks for your help, saved my a few quid there!!!
Thanks again.
That's what I call jumping on it!
Just hold the soldering iron on there briefly enough to just make the solder flow and you should be all set.
Glad that you saved a trip to the stealer!
Regards, Maurice.
