Old 01-19-2009, 12:28 PM   #1
insite
Originally Posted by markk
Blipping is imho done after selecting the next gear and before the clutch goes up. In practice I do it in parallel, i.e clutch in, selectnext gear AND blip, clutch up.
When you have mastered that, then try braking at the same time.
1. Brake hard with the top of your foot before a corner in high revs
2. Clutch in (during braking)
3. Blip the throttle with the bottom/heel of your feet AND select down gear with your hand - (still braking and clutch in)
4. Clutch up
5. Brake up
6. Steer into corner
this is pretty much the technique i use, except that i use the side of my foot to blip the throttle rather than my heel.
one thing to practice that leads to the above technique: while coasting in gear, give the throttle a SLIGHT blip while simultaneously pulling the shifter into neutral WITHOUT the clutch. if you do this right, the lever will easily slide out of gear.
for me, necessity was the mother of invention: when i was a teenager, i had a car that would stall out unless i stayed on the gas. to keep the motor alive, i learned to work the brake and gas with one foot. this lead to heel & toe; i do this ALWAYS, track or not.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
