Originally Posted by whitespyder
Insite-
so far from what you have experienced, how are they? Have you driven a boxster with pss9? if so, how do they compare?
to give them a fair shake, i have to get them dialed in first. i will have a chance next thursday to compare my car w/ ksports side by side with a 987 on PSS9's.
i pulled my rear struts today to re-set the top mounts; when i put it on the alignment rack yesterday, my MAX rear camber was -1.3 and my MIN front was -1.8; clearly i made a bad guess!
tomorrow i will pull the fronts & reset their top mounts. i may be able to vary the weight balance on the car a bit w/ ride height to minimize the harmonic issue.
once i have the ride heights and alignment in good shape, i'll continue my testing for a few more days on the street. after the track next thursday, i'll post my thoughts.
