05-02-2016, 10:22 AM
#161
Originally Posted by BruceH
Lovely, thank you!
Porsche Boxster S Type 986
05-02-2016, 12:48 PM
#162
2003 Base 5-speed
Yes, ordered some of that exact product. Thanks, Bruce and Ger
05-02-2016, 01:09 PM
#163
05-02-2016, 03:02 PM
#164
Originally Posted by geraintthomas
Lovely, thank you!
You guys are welcome
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
05-04-2016, 09:33 AM
#165
the little touches make such a huge difference! great job.
05-04-2016, 03:44 PM
#166
Many thanks
05-08-2016, 03:58 PM
#167
Greased my brakes today as they started to squeal a little - I forgot to grease them when I installed them. Oops!
While the wheels were off, I decided to try to remove the years of brake dust/fluid stains that were on the alloys.
Before (this was AFTER I washed the wheel!):
After:
Before:
After:
They're not perfect inside, but they were a nightmare to get clean. I had to use a mix of AutoGlym Custom Wheel Cleaner, 2500 grit wet and dry sandpaper, and Meguiars Ultimate Compound. They're far better, and seeing a clean alloy wheel barrel through the spokes is far more attractive!
Back wheel:
Front wheel:
Much better, you think?
05-08-2016, 05:49 PM
#168
2003 Base 5-speed
Looks great. Nice result.
05-08-2016, 06:46 PM
#169
So much better!
Have you tried an iron dissolver such as Iron-X or Decon Iron?
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
05-09-2016, 11:26 AM
#170
Thank you  quite pleased with it.
Originally Posted by TrumpyAl
So much better!
Nah I haven't actually, I don't know anything about it :/ you think that would help?
05-09-2016, 11:38 AM
#171
WALDMEISTER
Immaculate!
Nice work, looks fantastic.
05-09-2016, 12:31 PM
#172
2003 Base 5-speed
Ger's 2003 Porsche Boxster S
These products chemically react with the brake dust to break it down. This reaction causes the product to turn purple (and they have an odd sweet smell). Then you rinse off.
My experience with the Car Pro Iron X is it works well on removing light brake dust on wheel exteriors, but for that baked on, old, heavy duty kind in inner wheels no matter what product you use will need a significant amount of wet sanding, compound and elbow grease.
05-09-2016, 02:38 PM
#173
Aaaaahhh, Merlin's Blood, Very Cherry, etc. Gotcha, I didn't know what they were called or how they worked. Thanks!
05-09-2016, 05:34 PM
#174
I agree, it would take a lot of treatments to move that kind of buildup, and you'd still have staining to remove anyway. A wheel brush like a Daytona Speedbrush is the best weapon in your arsenal against buildup of that magnitude forming in the first place - when coupled with a user friendly non-caustic wheel cleaner they make it so easy and pleasant to maintain the drum. A small brush for around the nuts and you're set.
Iron-X or the like I'd recommend before your periodic wheel wax/sealant. So every six months for me. (but we don't have salted roads to deal with down under)
05-23-2016, 02:00 PM
#175
Good advice
Nothing much to report, just been running the car as usual. But today I decided to install some ambient footwell lights that are on when the lights come on. This mimicks the ambient light found up by the dome light, and bathes the foot wells in a very dim orange glow. When you open the door, a brighter light turns on.
Here's what was needed - wire, two bulbs, and a soldering iron:
Made a loom (testing it with a battery)
Then wired the positive into a 12v feed that the parking lights work from, and grounded the negative.
Done!
Footwells when you open the door (like before):
And now when you're driving at night:
Sorry about the quality, didn't have a tripod for the DSLR.
Very happy
05-23-2016, 03:18 PM
#176
Very nice work! I love the look and the bright/dim function  Pics look good enough to me.
DEPO Tail Lights
05-23-2016, 03:24 PM
#177
Thank you  I've been outside about 3-4 times now (it's 23:26 over here) to look at them in the dark. It looks awesome!!
05-23-2016, 06:05 PM
#178
2003 Base 5-speed
That's nice work, Ger. I'm not much for electrical work. How does the parking light feed "know" the doors open or close?
I did do a mini-mod the other day. I had replaced the ashtray with the non-smokers cup a while back. Doing so left a live wire under the console that used to power the ashtray light. I removed the bulb from the ashtray (kind of tricky), drilled a small hole in the cup, plugged in the light and inserted it (fit snugly) in the hole. Viola! I did add a dab of paint on the top of the bulb to reduce glare.
05-24-2016, 02:42 AM
#179
The wires that come out of the fuse box, I tapped into the ones that went to the courtesy light. They turn on whenever that turns on, and fade out as well when the courtesy light fades  All thanks to Particlewave for finding the information for me.
Quality mod too! I'm tempted to get the non smokers thing as well, so this may be something I do too
05-24-2016, 02:58 PM
#180
One of my alloys wasn't in the best condition, with curbing and lacquer peeling causing dirt to permanently show. I decided to give it a quick blow over with the spray cans. Only took an hour.
The alloy as it stood
This is the problem with it. This is as clean as I can possibly get it
Rubbed down the bad areas
Primer
First coat
Second coat
Lacquer
Finished
Looks much better on the car.
But then, just my luck, I dropped the wheel brace and it chipped the paint
Oops. Will go over that part another time, can't be bothered at the moment!
Either way it's far better now. To be honest I should have rubbed the whole alloy down as it's left a few areas a little 'bobbly' from where stones have hit the wheels over the years. But still, for an hours work I can't really complain.
Got me thinking though. What do you guys thing if I colour the wheels in anthracite?
HTML code is Off
