Old 08-26-2023, 10:38 AM   #1
elgyqc's Avatar
Airbag module replacement confusion.
I have read a lot of discussions on airbag modules and remain confused.
It is mentioned in many threads that the VIN number has to be programmed into a replacement airbag module, using one of Porsche's diagnostic tools. But there are a couple of threads of just replacing the module with a used one, resetting the error codes and all is good.
This is an example:
http://986forum.com/forums/diy-project-guides/51789-diy-airbag-module-replacement-reset.html
So is the reprograming of the VIN really necessary?
My Durametric gives a list of codes for the airbag, but the important ones are:
"3 - Supply voltage
195 - Control module internal fault - All fault codes over 100 indicate a critical fault and usually require a new control module"
I checked the supply voltage and it is OK... so it would seem that the module is defective.
Thus my interest in replacing the module.
Grant
Old 08-26-2023, 11:33 AM   #2
Yes, it may need to be coded to the car, depending upon where the module came from. If it is out of a similar year Boxster, probably not, if it is either new or reconditioned, or from a model other than a Boxster, then yes, it will need to be coded to the car. And it might be worth the cost to get it checked by someone with a PIWIS unit, a brand new module is about $1,200 at retail.............................
Old 11-26-2024, 01:36 PM   #3
Did you ever figure this out? I replaced my module and now I’m getting code 72 only. I can reset it but it comes right back.
Zogg is offline   Reply With Quote
Old 11-26-2024, 05:55 PM   #4
elgyqc's Avatar
No I never got around to replacing it, but since I'm selling the car I may have to do this in the Spring. Hopefully others will jump in.
Grant
Old 11-27-2024, 02:38 AM   #5
1998 Boxster Silver/Red
Remember when, in the old days, if you needed to repair something... needed answers... a manual... you went to the library, and they told you the book was out and would be retrned in a month...
No, you don't.
Hey... the Internet was invented. That devil, Google... worrks!
Fault codes 70, 71, 72, 73
Child seat detection
Diagnostic conditions
• Ignition on
Possible cause of fault
♦ Incorrect coding
♦ Plug connection of child seat detection belt buckle not connected or damaged
♦ Short circuit to B+/ground or open circuit in the wiring between the airbag triggering unit and the child seat detection belt buckle
♦ Child seat detection belt buckle faulty
1998 Porsche Boxster
