02-23-2004, 02:05 PM
b0xt0La
free parts catalogue?
Does anyone know of a free catalogue of Boxster parts and their prices?
02-23-2004, 05:15 PM
Tweeks^.....kinda expensive.
02-23-2004, 09:38 PM
What is it you want to look up?
02-24-2004, 03:56 PM
b0xt0La
The remote control part of the key.
02-24-2004, 10:38 PM
The entire key head? Sample pic.
02-24-2004, 10:57 PM
b0xt0La
yup toll pants that's the one
02-24-2004, 11:06 PM
What year?
02-24-2004, 11:15 PM
b0xt0La
1997, i got a new theft control unit and need a new remote control. they dont have the serial for the one i currently have so i have to get a new one.
02-24-2004, 11:25 PM
Do you mean you do not have the paper tag with the 24 digit code for your remote keys? I thought there was a way to get the code out of your old unit and transfer them to the new unit - but I would have to check the shop manual so I could be wrong.
1997 is different from all other years. Part number should be 986 637 243 01 with a full retail of about $130. Double check with your parts dept.
02-24-2004, 11:40 PM
I looked at the manual and I may not understand what I read.
But is says that when you replace the control unit the PST2 can read out the code and then the code can be inputed/transfered into the new unit and that way you do not have to replace the remotes. Also says you have to input the code correctly the first time because if you make a mistake then you cannot use the old remotes.
02-25-2004, 12:06 AM
b0xt0La
The exact thing i was told by my mechanic. I'm missing the tag witht he code. He showed me an audi key that has the same feqtures and such. I can buy a used remote from ebay and it will work on my car i have the correct serial. We don't at this point for my key. Towards the end of our conversation, the guy told me something about programing the "key" or soemthing. I was so confused I didnt even ask, he said that the key had to be programed. He told me he was confused himself and what not. They are Porsche and they promised to give me my car back in a perfect condition. Our Porsche dealer here is so professional. They ddint give me the BS the other mechanic did. They even told me to bring me to bring parts from the outside if I wanted too. And they could put it on. They actually said that to me and am so surprised that Porsche dealers would do such a thing.
02-25-2004, 12:10 AM
b0xt0La
PS: they tried to read my older unit but they were not successful. It was badly burned.
I love that Porsche computer. You can plug any unit into this thing and it will tell you stuff.
02-25-2004, 12:44 AM
I bought a used 1997 5 years ago and I am glad I got the paper tag. Now if I could just remember where I put it.
What do you mean about being burned. Like a fire?
Do not even look at an ebay key head unless it has the tag with the code for that head. The codes are unique and it must be for that head or it is worthless. With a non remote key head, the valet key, there is no tag.
I assume your unit that was replaced was replaced with a 1997 unit. If so, the remote must be for a 1997, as the unit for 1997 is different then all other years. A 1998-2000 remote will not work on a 1997.
The tag.
02-25-2004, 09:25 AM
b0xt0La
The unit shorted and burned out becuase water got in there some how. I'm not sure about the year of the unit but it's brand new. He looked up some info on it and told me that these units are unique and can only be programmed once.
Another question to you Tool Pants: Doesw a brand new "Folding Top Trans" come with the Lever? My motors are fine but the Lever on both sides are broken. But he said to fix the top I need to get 2 new trans one costs $472 and the left one for $421
02-25-2004, 09:35 AM
You probably mean the red plastic ball joint on the end of the push rod since that is known to break for various reasons. Look at this. http://www.renntech.org/forums/index.php?showtopic=68
02-25-2004, 02:30 PM
b0xt0La
The part circled is what I'm talking about (98656147901/8001). Also I need the rods which come seperately I suppose since they have a different part number (98656127902). I still don't understand why I need to buy a new motor if these are the only things broken.
02-25-2004, 02:46 PM
The V levers and push rods rods are separate parts.
Is there anything on your car not broken?
When you say motor - do you mean the top transmissions - one on each side. The picture you posted that I took is the transmission, not the top motor.
02-25-2004, 03:10 PM
b0xt0La
Hehe as for now it's just the top that's messed up. My piece broke off just like the one in the picture, the motor just kept turning and didn't stop which caused it to break. There are also some small parts that are needed like Lock Clip, Threaded Spacer and Plastic Sleeve which I don't know where they are in the pciture.
They said they will charge me $1900 to fix the top but I'm thinking about doing it myself since I have enough instructions thanks to you and the manul I've got. If decide to work on the top by myself, the only I'm worried about is breaking that lever again. The mechanic said that these are timed and should stop when the coloumn is completely closed.
02-25-2004, 03:18 PM
If you want to give it a go then try RennTech as Mark is the top expert - I just turn the wrenches.
Remove and inspect the top transmissions and if they are not damaged then reuse them. I have seen the transmissions from 3 cars with top problems and there was nothing wrong with the transmissions. It is the cables or the plastic joints, or in your case broken V arms. If you are lucky about $200 in parts will have your top like new.
