Old 02-24-2004, 11:40 PM   #10
Tool Pants
I looked at the manual and I may not understand what I read.
But is says that when you replace the control unit the PST2 can read out the code and then the code can be inputed/transfered into the new unit and that way you do not have to replace the remotes. Also says you have to input the code correctly the first time because if you make a mistake then you cannot use the old remotes.
Tool Pants is offline   Reply With Quote
