Old 02-25-2004, 03:18 PM   #19
Tool Pants
If you want to give it a go then try RennTech as Mark is the top expert - I just turn the wrenches.
Remove and inspect the top transmissions and if they are not damaged then reuse them. I have seen the transmissions from 3 cars with top problems and there was nothing wrong with the transmissions. It is the cables or the plastic joints, or in your case broken V arms. If you are lucky about $200 in parts will have your top like new.
Tool Pants is offline   Reply With Quote
