Old 01-18-2020, 05:31 PM   #1
Who's askin'?
maytag's Avatar
Should I dial-out this play in my shifter?
Hey y'all. So, I was swapping shift cables, asd I have a set with half the miles on them from a parts car. I'm also waiting for Ben's new side- bushing to arrive from uniwerks.
In the meantime two questions y'all could weigh in on?
1. See the short video below. You'll see some fore-aft "slop". About an 1/8". If I'm seeing the parts correctly, I can dial that out with the studs in the ends of the cups?
Any reason I shouldn't? I mean, does the shifter bind if it's tightened up, or something?
https://youtu.be/wlc0Q_xY890
2. I took the cables out weeks ago..... and I'm older than I used to be, hahaha. Somebody check me: left cable (white) goes to the "front" lever on the 6-spd trans, and the right cable (geen) goes on the rear, correct?
Old 01-18-2020, 05:40 PM   #2
Who's askin'?
maytag's Avatar
Nevermind..... I looked again. That play is there to stay. No adjustment.
Sorry.... long day. Cold garage. Haha
Old 01-19-2020, 09:19 AM   #3
Racer Boy
Racer Boy's Avatar
Maytag, have you used the short shifter on-track yet? I have a short shifter, and am thinking about getting rid of it. The throws are so short, which is fine for the street, but on-track it's easy to get the wrong gear when you are busy trail-braking and steering into a corner and you need to downshift. I'll admit that I'm rusty, but it just takes too much focus on shifting to keep from blowing a shift. I never grabbed the wrong gear when I had the stock shifter.
From what I've read, the 987 shifter is right between the stock shifter and Ben's shifter. Maybe I'll get one of those.
Old 01-19-2020, 11:47 PM   #4
Shapeshifting Lizard-Man
WizardSmokey's Avatar
I've got the Ben's shifter on my track 986, and you'd have to pay me an awful lot to go back to the stock shifter. I had an issue with the stock shifter of hitting the gap between first and third when going up from second. No problems since I got the short shifter.
WizardSmokey is offline   Reply With Quote
Old 01-20-2020, 05:00 AM   #5
Who's askin'?
maytag's Avatar
Hmmmmm....... interesting question.
Yes. I've used the short shifter on track. But I haven't used the stock shifter on track, so I can't really compare.
I DO have the occasional difficult time getting into the correct gear while downshifting... but until you asked that question, I was ready to just simply chalk that up to "need more seat time". I am still working on muscle memory to help slow things down a bit. When I'm heel- toeing, blipping for 2 down shifts, starting my turn-in, etc.... it still feels a little frenetic on occasion. And this is when I sometimes grab the wrong gear. (Yeah.... the WORST time to do it. Hahaha)
Old 01-20-2020, 06:12 AM   #6
steved0x's Avatar
I've used stock shifter (rubbery and worn out), 987 shifter, much better, Ben's shifter, even better. Used all 3 extensively on track. Ben's is my favorite on the boxster.
On my Cayman I'm still on my original shifter, I have a 2nd Ben's but haven't been in a rush to install it since the Cayman shifter has been working well (even better than when I had one on the boxster somehow). And I subsequently scored a deal on a numeric shifter, so that will probably go in at some point...
I highly recommend Ben's and while I don't have the side bushing I'm sure it is great too.
Old 01-20-2020, 07:36 PM   #7
jaykay's Avatar
How does Bens compare to a B+M?
986 00S
Old 01-20-2020, 08:16 PM   #8
Who's askin'?
maytag's Avatar
Everything I hear is that Ben's is far superior. But I've only ever experienced Ben's.
Old 01-21-2020, 05:54 AM   #9
husker boxster's Avatar
This is what I used on my CSS. Huge improvement from stock. Not sure how it compares to Ben's, but this was up there on the best $300 I've spent.
FUNCTION-FIRST > Shift-Right Solution
1989 928 S4 5 spd - black
Old 01-21-2020, 07:13 AM   #10
Nine8Six's Avatar
Ben is about to finalize a prototype which I'm sure will involve stability. He haven't given much details in his last comment although I'm sure someone can ask and/or propose improvement(s). Best time to do so now imo i.e. while he's busy improving his already good shift kit!
http://986forum.com/forums/609908-post695.html
Old 01-22-2020, 04:25 PM   #11
jaykay's Avatar
The B+M is extremely short and does not work well with my 6 speed. I was wondering if Bens is less so. Would it be similar to the 997 SSK which I have been using for a while?
The 997 SSK is now worn and needs metal bushings.
An extended shift knob really makes the difference on six speeds.
986 00S
Old 01-22-2020, 07:20 PM   #12
Who's askin'?
maytag's Avatar
Does anyone have the installation instructions for Ben's side lever?
I'd sure love to review it before opening it all up. The package didn't come with anything but stickers. ;-)
