Old 03-12-2019, 05:38 PM   #6
The Radium King's Avatar
ticking can be a number of things:
- noisy injector - get them serviced at rce or similar. easy.
- stuck lifter - there's a cleaning product you can run through the engine, otherwise an invasive fix.
- piston slap - bad news. will also present as excessive oil consumption (as oil weeps past scoring on cyl walls).
i've not tried it, but apparently some listening with a stethescope can isolate where the noise is coming from and help determine the cause.
futher, this is 'internet common knowledge' for the m96/m97; nut sure if you have an m97 or direct injection?
Tags
987 , 987.2 , cayman
