Old 01-12-2018, 09:07 AM   #1
Artist, 986S tinkerer
NewArt's Avatar
Who can push a 986 special edition tune?
I am doing the 987 airbox/74mm TB mod in my 2004 Boxster S and would like to use the 987 maf. For this, I beleive that the best way would be to use the special edition tune. The problem is: where on earth cane I get this file and can it be loaded into my existing ECU?
Old 01-12-2018, 09:25 AM   #2
That will require access to a legitimate PIWIS system.
Old 01-12-2018, 09:55 AM   #3
The Radium King's Avatar
you will also need the codes for your car - specifically, the DME programming code. not easy to get. porsche is supposed to give them out but never does. you gotta know a 'guy' to get them. perhaps pm 986bsdriver to see what he is going through to get his. i *might* be out east in may, and could bring my pst2, but really up in the air at this point (currently losing on both sides of the money/time equation). otherwise, i have the old ducting left over from when i was running a base tune with 987 airbox and TB that i could send you.
Old 01-12-2018, 11:04 AM   #4
NewArt's Avatar
@TRK Were you using the 986 MAF with your setup?
Old 01-12-2018, 12:01 PM   #5
before i went to a 996 tune in order to use the larger MAF holder, i had the 987 airbox and an adaptor to reduce down to the 986 MAF holder that i swapped off my old airbox. i have this adaptor though to the silicone elbow onto the throttlebody if interested.
Old 01-12-2018, 12:41 PM   #6
NewArt's Avatar
before i went to a 996 tune in order to use the larger MAF holder, i had the 987 airbox and an adaptor to reduce down to the 986 MAF holde rthat i swaed off my old airbox. i have this adaptor though to the silicone elbow onto the throttlebody if interested.
Certainly interested! I'll send you a pm.
Old 01-12-2018, 05:17 PM   #7
BYprodriver's Avatar
I told my local dealer service manager my engine failed so I was installing a different engine & converting to a racecar. He called PCNA & gave me the codes.
Old 01-12-2018, 07:20 PM   #8
NewArt's Avatar
How did you upload the codes?
Old 01-12-2018, 09:17 PM   #9
It's certainly not easy to get the codes and every place has its reasons why they don't want to hand them out. I gotta be present with proof of ownership which isn't a huge issue, except I was on vacation with a different car. I did pay the dealership for the radio code though, they would not hand out anything else Other then that.
986bsdriver is offline   Reply With Quote
Old 01-12-2018, 09:57 PM   #10
the codes come as numbers on a piece of paper, associated with the VIN and specific to each car (ecu, gauge cluster, immobilizer). you type them into the pst2/piwis when pushing the new tune.
Old 01-13-2018, 12:23 PM   #11
My PST-2 I bought from Todd Hollyoak.
Old 01-13-2018, 07:02 PM   #12
NewArt's Avatar
I sent you a pm but haven’t heard back. p
Old 01-13-2018, 07:24 PM   #13
ditto. that todd gets around.
Old 01-14-2018, 04:58 AM   #14
"50 Years of 550 Spyder"
10/10ths's Avatar
I can push....
....my 550 SE down my driveway.
Does that count?
Old 01-15-2018, 07:02 AM   #15
NewArt's Avatar
Does that count?
Only if you can push it back up! :dance:
