Old 05-29-2017, 07:46 PM   #21
There Is No Substitute.
rick3000's Avatar
That Pelican guide should really be a little more explicit about which instructions are for which transmission. I double checked my Bentley manual, and for the 5-speed it should be 11mm below the fill hole.
Old 05-30-2017, 06:22 AM   #22
Damn!! Is overfilling bad?? I can't get back to the lift for atleast 2 weeks! Will it be ok?
Vidyashankara is offline   Reply With Quote
Old 05-30-2017, 01:15 PM   #23
Overfilling puts an extra load on the gears inside the transmission. You can draw it down without a lift. Floor jack and jack stands do the job.
1941 Dodge Luxury Liner Coupe
Old 05-30-2017, 01:21 PM   #24
The larger issue with overfilling the gear box is oil getting onto the clutch via the input shaft when the oil gets hot.
Old 05-30-2017, 05:20 PM   #25
I will try and do this in the next couple of days. I still need to remove the aluminum tray and diagonal brackets covering the transmission right?
Old 05-30-2017, 05:27 PM   #26
Not sure. I have the 6 speed and the fill plugs are in different locations.
Old 05-31-2017, 02:27 PM   #27
2003 S, Arctic Silver, M6
paulofto's Avatar
Save time, effort and a lot of potential alignment issues and drill an 2" diameter access hole in the tray. You'll be happy you did.
To remove just a little fluid, remove the fill plug and jack up the from end, some fluid will leak out the fill hole and then level the car and see if the 11 mm difference is met.
Old 06-01-2017, 10:21 AM   #28
Awesome, thanks! Can you explain the potential alignment issues?
The hole will give access only to the drain plug right? I am not sure if i can access the fill plug without remove the tray.
Old 06-01-2017, 02:35 PM   #29
paulofto's Avatar
You should be able to get at the fill plug with the tray in place. It may be a bit awkward but accessible. The fill hole for the 6 speed is more accessible.
The alignment issue comes into play when the tray is removed. It is a bear to get back in and align it with the bolt holes in the two support arms. Wrestling it back in is a pain and could result in things not lining up correctly.
Old 06-01-2017, 02:40 PM   #30
You definitely want to use the OEM Porsche transmission fluid, it is specific to the transmission, and people seem to have issues using non-OEM fluid. The PN is: 000 043 304 71. I do not think it is available in individual liters anymore, you have to buy a drum of it. However, Sunset Porsche sells it by the liter (they fill up empty/clean oil cans). You will need 3 liters, which runs about $80. If you try to buy it at the dealer, don't let them sell you anything other than that part number, it is not the same.
This is right, 2000 and older use a special oil. It is not the same oil for the later models as Rick very correctly states. It will make a difference, I went to the dealer and they sold me the gear oil for the later models, and its did not work, the shifting was balky and when I put in the correct oil, it shifted perfectly.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-01-2017, 06:26 PM   #31
rick3000's Avatar
I spent a few hours researching the transmission oil for the '99 before I changed mine. Porsche really went all out on the early five-speed's and the oil is in fact specific to the transmission. It's a shame most dealers will try to sell people the wrong fluid, because they don't stock the 20L drum. Don't trust the parts guy at the dealer!
The plate is part of the suspension system, it acts as a brace between the rear suspension, and when you remove it, you can change the alignment of the car. If you choose to remove it and not drill a hole, use jack stands and not ramps. By taking the weight off the wheels you will reduce the chance of messing up the alignment. When I removed the plate I used stands, and when I had my alignment checked afterward it had not been affected.
Old 08-31-2017, 07:46 AM   #32
I was due to change my transmission oil ('01 S, ie 6 speed), so I gave my semi-local Porsche dealership a call. Turns out what they sell for DIY purposes is Valvoline 75W90. I guess I'll check with the folks at Sunset. In the 101 Projects book Wayne also mentions using Mobil Delvac Synthetic Gear Oil. Anyone have any experience with it?
My driveway is sloped. When I do an engine oil change I point the car uphill then back it onto homemade ramps. By finessing it a bit I can get the car nice and level and still have access to shimmy underneath and reach the drain plug & filter.
With changing the transmission oil, if I did the same thing but, instead of using ramps, jacked the back end up and then put it on jack stands, could I avoid the potential alignment issues? The other thing I'm wondering is this: I feel very safe under the car on the slope using the ramps for doing an engine oil change. OTOH I'm suspecting it may be a bad idea to use jack stands on a slope, even a pretty gentle slope like what I'd be working with. Actually, if I do it right I can have just the front end of the car on the sloped part of the driveway while the rear end (where the jack stands would go) is still on the flat part.
When you guys have done the transmission oil have you put the car on stands on all 4 corners? (I wish I'd bought a lift years ago... )
Old 08-31-2017, 07:56 AM   #33
I just noticed that the Mobil synthetic transmission oil question was already addressed earlier, so I probably don't need any response on that. OTOH, if anyone's used it and found absolutely no decrease in performance or smoothness of shifts, I'd be interested in hearing about it.
Old 08-31-2017, 09:04 AM   #34
Capri Tools 1/2 in. Drive 16 mm XZN Triple Square Bit Socket-CP30055 - The Home Depot
IS this the socket used to remove the drain plug in the 5 spd transmission?
Is that same socket for 2003 Boxster 5 spd Trans.?
I'm newbie I just purchased this car 3 months ago has 71K miles no service record or one's manual. When do I replace the Trans. Fluid? at 100K ?
JOC IN IL is offline   Reply With Quote
Old 08-31-2017, 01:26 PM   #35
According to Bentley should be the same socket.
On how frequently to change the transmission oil opinions vary. The Bentley manual (which I assume is based on Porsche recommendations) says only every 90k miles. Wayne, in his 101 Projects book, recommends every 30k miles. I tend toward somewhere in between.
Old 08-31-2017, 03:27 PM   #36
30 to 40K miles is the optimum window, depending upon how the car is used (track cars change sooner).
Old 08-31-2017, 03:57 PM   #37
I'd listen to him...he kinda knows this stuff pretty well..
New info: I contacted the folks at Sunset, asking about their transmission oil. He replied, "This is the Mobilube PTX 75w90 transmission fluid. Porsche only sells it in 20 liter containers so we break it down in to individual liters for our customers."
I was thinking the "Porsche stuff" was a Shell product. I'm not sure exactly what constitutes OEM transmission fluid in P-cars anymore. Is this Mobil product the one that is so much better than the other oils out there? The stuff that you, JFP, have had customers drain out other transmission oils to put in?
Old 08-31-2017, 06:03 PM   #38
Porsche currently has two approved 6 speed lubes, this is one, the other was a Shell product. The early 986 base cars with a 5 speed used a totally unique product which was made by Burmah, which is also a Shell subsidiary.
Old 08-31-2017, 06:57 PM   #39
Okay, now we're gettin' somewhere.
So, when people say it's best to use the Porsche transmission oil, that it's so much superior to the competition, that would apply equally to both the Mobil and the Shell products?
BTW, I have no axe to grind here...I'm just trying to figure out what's going into my gearbox.
Old 08-31-2017, 07:32 PM   #40
Looking at this again, I should re-word: Not what "you, JFP, have had customers drain out other transmission oils to put in?"
What I meant to say is what "you JFP, at the request of your customers, have drained out of transmissions to put in?" I'm pretty sure you weren't holding a gun to their heads..
