Old 02-04-2017, 06:35 AM   #1
Dave80GTSi's Avatar
Composition of the exhaust manifold catalytic converters
Does anyone know the construction composition of the primary catalytic converters, the one integral to the exhaust manifolds, as shown?
Specifically, are they metallic or are they ceramic?
Thanks - DM
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
Old 02-04-2017, 08:16 AM   #2
They are a ceramic honey comb which is coated or impregnated with metals such as platinum which fosters the desired chemical reaction to reduce pollutants in the exhaust stream.
Old 02-04-2017, 05:45 PM   #3
Dave80GTSi's Avatar
Interesting, thank you!
So the manifold cats are made of ceramic, while the secondary cats further back are metallic-core based?
Old 02-04-2017, 06:18 PM   #4
No, the are both ceramic with metal coating/impregnating.
Why are you asking?
Old 02-05-2017, 05:58 AM   #5
Dave80GTSi's Avatar
I recently cut open a secondary cat that some guy had tried to gut, apparently using something like a crow bar and a sledge hammer.
These cat cores are made of metal, so that his efforts to break up the core simply bent it all into a metallic lump. Presumably had the core been ceramic, it is brittle enough so to break up into small chunks under such crow bar force.
My original question was out of curiosity, simply to wonder if the manifold cats were also made of the same metallic construction.
Seems to me that a ceramic core would hold up better under the higher heat exposure so close to the engine.
Thanks - DM
Old 02-05-2017, 06:50 AM   #6
steved0x's Avatar
Stealth cat delete pipes
Old 02-06-2017, 03:07 PM   #7
AZ986S's Avatar
Funny, I just pulled mine.
Now I understand the "restriction" thing...
Next item on the list: high flow exhaust headers!
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 04-15-2017, 04:34 PM   #8
Dave80GTSi's Avatar
Thanks - DM
Now able to answer my own question.
Both the manifold and the secondary cats are identical in construction materials, and both are made of a non-ceramic metallic honeycomb.
So you can't bust a thru hole via brute force, a crowbar, and a sledge hammer. Like someone - not me - tried to do, as shown in the picture which I posted here earlier.
DM
