Old 11-15-2016, 12:43 PM   #1
now is the time
Ok, now that my car is out of commission (without gearbox and complete suspension)
This is the time to take care of a pesky oil leak from the 1-3 bank, and without the gearbox and suspension I should have enough room to lower the engine a bit more to remove the cam cover.
The question for JFP: Do you know if I will be able to replace the seals on top of the lifter carrier (3..?) without removing the camshafts?
Also, I am trying to locate the tools to lock the cams at TDC and to hold them in place while removing the cam cover, hopefully I would be able to borrow them or rent them (So. Cal)
Any leads for the required special tools will be greatly appreciated, thank you.
Gilles
Gilles is offline   Reply With Quote
Old 11-15-2016, 01:31 PM   #2
While you are in there.....
look carefully for leaks from
1. the base of the oil/water cooler.
2.The p/s filler neck.- there are 2 'O' rings inside the stem of the neck and one on the cap.It is a bayonet- twist fitting .It may be a good idea to add a hose to the overflow nipple. 5.5mm hose.
