		|  03-16-2016, 08:22 AM | #1 |
	| Registered User
				Mobil 1 0W-40?
			Any buddy have anything good or bad to say about this 'European' blend of Mobil-1?  Says it is for Audi, Porsche, mercedes etc.  Also fully synthetic.  I am thinking of using it this year instead of my Castrol.
AKL
				'02, Arctic Silver/Graphite Gray, 2.7, TIP,  2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.    15mm spacers fore & aft.
		|  03-16-2016, 08:41 AM | #2 |
	| Registered User
			With all of your posts you have the Balls to ask a question about oil!!!!
 Let the games begin
 Oh by the way - I use it
 Main complaint, noisy startup after long inactivity
				__________________2002 S - old school third pedal
 Seal Grey
		|  03-16-2016, 08:53 AM | #3 |
	| There Is No Substitute.
			Not another oil thread!
There is tons of info on this, please use the search feature.
There isn't anything wrong with Mobil 1, I was using it, but recently switched Castrol per the recommendation of some very knowledgeable people on this forum.
				__________________1999 Ocean Blue Metallic Boxster - blueboxster.com
		|  03-16-2016, 09:28 AM | #4 |
	| Registered User
			From the Porsche Dealership in Toronto Downtown Porsche Mobil 1 0W 40.
				__________________Frank
		|  03-16-2016, 10:01 AM | #5 |
	| Motorist & Coffee Drinker
			I'm pretty sure that this decal was paid for by Mobil at a cost of many times the price of the decal:
My 2001 owner's manual does not have ANY recommendation of a 0 weight oil:
0 weight Mobil1 oil? I put in in one of mine because it was on sale. Next 6 month change I think it's going to 10W-40 Castrol Edge, if the engine hasn't had a catastrophic failure by then. :dance:
				__________________I am not an attorney, mechanic, or member of the clergy. Following any advice given in my posts is done at your own peril.
		|  03-16-2016, 12:17 PM | #6 |
	| Registered User
			Mobil 1   15 w-50 for me out here in sunny CA :-)
				__________________2000 S - Borla Exhaust, TS Cat Deletes, RSS UDP, B&M Short Shift, T96 Steering Wheel, Potenza RE-71R's,
		|  03-16-2016, 12:35 PM | #7 |
	| Registered User
			Mobil 1,  0 W-40
				__________________2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
		|  03-16-2016, 02:02 PM | #8 |
	| Registered User
					Originally Posted by kk2002s  With all of your posts you have the Balls to ask a question about oil!!!!
 Let the games begin
LOL!  Just noticed the designation on the container about being for Porsche and other German cars and wondered if this was something new I was missing.  I also have the spin on filter from L&N and he recommends  5x 40.
Also nice to stir the pot from time to time.
AKL
		|  03-16-2016, 04:50 PM | #9 |
	| Registered User
			Cue up my non-scientific Mobil rant:
 Many years ago I used Mobil 1 exclusively. Then about the time that Exxon merged or bought out Mobil, I noticed that when I was pouring the oil into my BMW, the pour point seemed different, and the color had changed somewhat, though I was using the exact same viscosity type that I always had.
 Then I read on Bob's the Oil Guy that Exxon Mobil had changed from using one class of synthetic type to another class. By "class" I am referring to something called a PAO class. As I recall, they had changed from a Class IV to a Class III.
 I'm not sure if a Class III is really a bad oil, but the fact that this company changed their product without any other labeling change felt like a bait and switch to me. So, I will never ever use another Mobil product.
 By the way, I use Red Line exclusively now.
				Kippis
986S
991S
Van Diemen RF97
		|  03-17-2016, 11:52 AM | #10 |
	| Registered User
					Originally Posted by 78F350  0 weight Mobil1 oil? I put in in one of mine because it was on sale. Next 6 month change I think it's going to 10W-40 Castrol Edge, if the engine hasn't had a catastrophic failure by then. :dance: |
A very common misconception is that the "W" stands for weight. That's not true.  It stands for "Winter" and just means that the first number is the viscosity rating at 0 celsius.  The second number is the viscosity rating at 100 degrees celsius (212 fahrenheit) which is generally operating temperature. So it's the second number that you're really concerned about.  The biggest advantage of a low Winter number is quicker flow at startup.
A great read for oil basics is Bobistheoilguy.com's Motor Oil University blog. Motor Oil 101 - Bob is the Oil Guy - Bob is the Oil Guy |
		|  03-17-2016, 01:53 PM | #11 |
	| Registered User
			My box runs with a synthetic 5W-50 engine oil into next season. Less sound from the hydros when cold starting. Also i didn't drive the car in winter time / season. So i think there is no need for a 0W oil for me.
 Regards, Markus
		|  03-17-2016, 07:48 PM | #12 |
	| Registered User
			According to the M96 experts ,our engine has some unusual characteristics that require an equally unusual oil specification for best results.The optimum Track and street choices are differentThree of the issues I recall are:
 1. anti-foaming additives
 2. high shear resistance
 3. high thermal stability
		|  03-20-2016, 06:12 PM | #13 |
	| Registered User
			Mobil 1 0W-40; tastes great, less filling, no lingering aftertaste!
		|  03-20-2016, 07:51 PM | #14 |
	| Certified Boxster Addict
			Mobil 10W-40 High Mileage changed every 10 hrs of track time (of course, those 10hrs are almost all at/near redline and wide open throttle!).
 I figure that any good quality oil that is changed often will probably do the job just fine regardless of brand or exact weight.
				__________________1999 996 C2 - sold - bought back - sold for more
		|  05-27-2016, 12:05 PM | #15 |
	| Registered User
			Anyone use the European formula or do you guys use the regular Mobil 1? I am trying to get oil for my first oil change and I am lost.
 Is there a standard recommended filter that you guys use? I don't need the absolute best with a ridiculous price. I need to know what's a good budget friendly recommendation that's not garbage.
				__________________01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
		|  05-27-2016, 12:10 PM | #16 |
			I'm pretty sure the 'European Formula' label is just a marketing thing, it's still Mobil 1 0W-40.  It's worth mentioning that Mobil 1 is not what it used to be.  You can read a ton about oil on this forum, but I switched to Castrol 10W-40 so you may want to look at that.  I also switched to a spin on oil filter but I was previously using the Wix/NAPA Gold 7211 Oil Filter, which seems less prone to disintegrating on the ends than other paper filters.
		|  05-27-2016, 12:22 PM | #17 |
	| Registered User
				Had to switch to JG 5W-40
			rick3000; My car is draining the last of the Castrol Edge as I type. I had to switch so I am going to the Joe Gibbs oil. None of the Auto Parts stores around here can get the Castrol 10W-40. O'reilly's had 7 qts and said no longer available??? Figured if I was going to pay $9 + for the Castrol that I'd just go ahead and pay $10.00 for the JG.
 IS this a Commiefornia thing?
 :troll:
						Reason: Political insurrection
		|  05-27-2016, 12:29 PM | #18 |
			I wasn't aware that it was becoming unavailable?  It's still listed on the Castrol website.  I bought some at Pep Boys last week for $6/qt (although it was in the back, not on the shelf), and Amazon has 6qts for $50, so about $8.50/quart.
		|  05-27-2016, 01:22 PM | #19 |
	| Registered User
			Just changed mine I went to Motul Xcess 8100 5/40 seems a lot quieter on startup but that may be the new oil . I cut the filter up thankfully there was nothing in it metal or plastic
				__________________2000 Triple Black Boxster S
 2017 Subaru Outback Grey
		|  05-27-2016, 01:27 PM | #20 |
	| On the slippery slope
			Wally world M1 ~$22 for 5 quarts and until 5/31 there is a $12 rebate on 5 quarts, 2 per address max
				__________________2004 Boxster S 6 speed  - DRL relay hack, Polaris AutoTop DIY
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 02:05 PM.
