Old 01-16-2015, 03:09 AM   #1
Where does this ground cable go
I was changing the AOS the other day and noticed a
Ground cable not connected. Does anyone know where it goes
Trendy996 is offline   Reply With Quote
Old 01-16-2015, 09:34 AM   #2
BYprodriver's Avatar
I think it bolts to the starter
Old 01-16-2015, 10:29 AM   #3
That's weird if it does considering its size and it not causing any ill effects with it disconnected
Old 01-16-2015, 11:01 AM   #4
Motorist & Coffee Drinker
78F350's Avatar
If you didn't already get it, yes that is the ground for the starter. The end you have open, mounts on the frame for the blower.
Old 01-16-2015, 11:49 AM   #5
Thank you guys 👍
Old 01-16-2015, 03:34 PM   #6
Beginner
Jamesp's Avatar
Be sure to bolt it back up to blower bracket. Parts of the car not meant to carry current are doing so. This can translate into corrosion in weird places, like inside the water jacket, and burning out whatever happens to be carrying the current during high loads such as starting.
2003 S manual
