Old 09-23-2014, 03:56 PM   #1
jaykay's Avatar
Chain tensioner - new or used???
Just pulled this out of the box........looks like damaged goods
Is this a slightly used chain tensioner or just a victim of the parts bin/hopper? Thread flanks look pretty clean but WTF?..
986 00S
Old 09-24-2014, 09:15 AM   #2
BYprodriver's Avatar
That does look pretty rough. How is the O-ring? Did it come with a sealing crush washer?
Old 09-24-2014, 10:36 AM   #3
jaykay's Avatar
The oring and thread flanks look to be okay so it's quite strange.....I bought the crush ring separately so it is good
I am going to exchange it if I can.....just to be sure of the internals
I posted as I was wondering if this common....and this is how they come
986 00S
Old 09-24-2014, 10:47 AM   #4
I've never seen a new one all dinged up on the end like that. If you use it be sure to pump it up in new oil before install.
Old 09-24-2014, 04:50 PM   #5
jaykay's Avatar
I was going to use a cup of my current engine oil and compress them by leaning on them.....release and lean until they are hydraulically locked....and then install
Jeeez what do you have there? Timing chain frickazee........hmmmm yum!
986 00S
Old 10-12-2014, 12:47 PM   #6
fasted911
fasted911's Avatar
Send a message via AIM to fasted911
Red face
so are you using the old cam to cam chains or new.
fasted911 is offline   Reply With Quote
Old 10-12-2014, 04:51 PM   #7
jaykay's Avatar
Installed new tensioners and start noise is much reduced
986 00S
Old 10-13-2014, 05:05 AM   #8
fasted911
fasted911's Avatar
OK. on tensioners.but can I re-use cam to cam chains?
Old 10-13-2014, 10:06 AM   #9
jaykay's Avatar
Cam chain removal requires engine removal and disassembly. Yes, if I was there I would change them. The items discussed here are cam chain tensioning mechanisms (for the cam chain paddles/ramps) which can be withdrawn from the engine without disassembly or engine removal
986 00S
