Old 11-05-2013, 08:15 PM   #23
Originally Posted by ganseg View Post
Which bearing did you install?
SKF 6204 RSH JEM single row bearing. 2RSH means it has two seals, but obviously I removed one seal. The "RSH"is SKF's new and improved seal. JEM means it has a C3 tolerance to account for thermal expansion. The OEM bearing had C3 tolerances too since the bearing operates in a hot environment, so I stuck with that. The OEM bearing was from the NSK brand, but I prefer and predominantly use SKF at work.
Kirk Bristol
