09-05-2013, 08:24 AM
#21
I going to have my associate Whitey Bolger get in touch with you, he knows how to handle squealers. He owes me a favor so don't worry about payment!
09-05-2013, 09:21 AM
#22
I prefer "Rifleman Flemi" if it's ok.
09-05-2013, 09:46 AM
#23
I've become a victim of my own sarcasm and loquacity
Oh...sweet irony...
2003 Cayenne Turbo
09-05-2013, 10:04 AM
#24
Originally Posted by Nine8Six
I think what he meant is he can hear it, the drone sound, you know
are your holidays nearly finished madmods?
09-05-2013, 10:08 AM
#25
JD solution-but plug!
09-07-2013, 06:35 AM
#26
Ye reap what ye sow big guy!:ah:
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
09-13-2013, 05:49 PM
#27
Many have pm'd me suggesting that it may in fact be a loose plug after all. Sound plausible ?
09-13-2013, 07:51 PM
#28
seat.....edge.......resolution I cannot wait!
09-17-2013, 05:46 PM
#29
I checked for a loose spark plug(s), along with a possible loose the 02 sensor, today. Everything was ok - the squeal continues.
09-17-2013, 06:52 PM
#30
Get yourself a roll of this and have a party under the Dangermobile.
Aluminum Foil Tape :3M US
Jäger
300K Mile Club
09-18-2013, 02:03 AM
#31
JD...
Does the noise disappear when the underside is wet (I know you don't take your car out in the rain...) but if you spray water - or better still kerosene - onto the engine mount / suspension / exhaust and see if the squealing reduces or - even - disappeares.
I suspect a dry engine mount or exhaust joint.......
2001 MV Agusta F4.
09-18-2013, 06:19 AM
#32
Originally Posted by Steve Tinker
JD...
The squeal persists, even when driving in wet conditions. As far as a dry engine mount is concerned, anything is possible, but it seems very unlikely due to the symptoms.
09-18-2013, 06:57 AM
#33
Did you mention whether it was proportional to engine speed?
Could it be that the header or header gasket is not torqued down properly and leaking a bit.
From too many years of experience, always consider the most unlikely to be perfectly possible, especially when you've run out of logical ideas.
In light of that you might also want to check for a covertly planted critter whistler or a racing pig taking up residence near by.
09-18-2013, 07:04 AM
#34
Perhaps a noisy belt or accessories being run by it are the problem.
You might also want to check for a covertly planted critter whistler or a racing pig thinking your a lap car.
The squeal persists at idle (especially warm up), and is more pronounced with "blips" of the throttle and falling RPM's. As I mentioned, the squeal can be isolated by putting pressure on the exhaust in various locations. So far, the hanger, clamps and strapping have all been checked for looseness, and tightened if needed.
09-18-2013, 08:30 AM
#35
google "whistling cat converter"; whistling can be a symptom of a clogged cat.
except I reread your initial post - you ruled out your cats?
09-18-2013, 09:11 AM
#36
2003 Cayenne Turbo
