Old 07-24-2013, 11:52 AM   #1
jaykay's Avatar
OBD2 Canada vs USA 2000
I have been told that it appears that the Boxster has a separate ECU program for the US
which doesn't seem to include Canada. The Durametric tool
uses Porsche specific diagnostic functions, it would seem that the
non-US version may not support standard OBD2 functions.
Is this the case? My US bought OBD 2 gauge is not working!!
I had always thought the ME 7.2 for US and Canada were the same!
The ROW would be a different story
986 00S
Old 07-24-2013, 02:05 PM   #2
To my knowledge, the only difference between the US and Canada DME programs had to do with daytime running lights, otherwise they are the same.
When you say you Durametric software "is not working", what are you referring to?
Old 07-25-2013, 07:12 AM   #3
jaykay's Avatar
Durametric works fine of course but my OBD 2 based dash gauge does not as apparently it was made to work with US cars. This does not make sense to me. I do have a Softronic flash loaded but it should not affect anything.....Stumped!
986 00S
Old 07-25-2013, 10:40 AM   #4
I'm not; some aftermarket DME "flashes" keep from throwing codes by shutting down sensors and flat out lying to the DME (creating a bogus signal). We recently had a 996TT that could not pass state emissions inspection because the DME could not properly read the O2 sensors, as soon as the car was reflashed back to stock, everything read fine and it passed. Interestingly, the car did not run any different on the stock DME program.
Old 07-25-2013, 11:39 AM   #5
The Radium King's Avatar
perhaps your obd dash unit is looking for info in imperial and you are producing metric info; might be as simple as a switch back.
Old 07-30-2013, 10:56 AM   #6
jaykay's Avatar
Good thought. I will check it out ....it may be an intialization time error where comm is not established in time for the dash to initialize...sooo it shuts down. I am just going by the display response
986 00S
Old 07-30-2013, 10:58 AM   #7
jaykay's Avatar
Yes I am hoping mine is not doing this. I would image the Soft flash would be reasonable quality.
986 00S
Old 07-30-2013, 11:08 AM   #8
Quality and price does not enter into it, a lot of them use these tricks.
