Old 01-25-2013, 08:28 PM   #1
02 box s
It's always something
Ok so going in to install the new o2 sensors I found that the shop that did the install of the headers didn't tighten the transaxle cover. I am missing a bolt. It is one of the two at the front of the pan. Can someone tell me what size they are? Maybe a part number? Thanks guys. Trying to keep things ship shape.
sgt brad is offline   Reply With Quote
Old 01-26-2013, 05:57 AM   #2
Theoretical propagandist
Eric G's Avatar
Take a look here so you can pick your year:
Porsche Boxster Axles & Bearings - Page 2
Old 01-26-2013, 07:22 AM   #3
02 box s
Thanks Eric. Unfortunately I tried quite a few of the parts diagrams, but the bolt is not shown. It appears to be an m10 bolt with flange. I may just take the one off and go to the parts store. I was just hoping to get one while it was still on the lift.
Old 01-26-2013, 07:26 AM   #4
Are you talking about the bolts that connect the Trans to the Motor? Naa, that can't be, just reread your initial post.
Old 01-26-2013, 07:46 AM   #5
02 box s
Hey mark, no it the pan under the trans. It has two bolts fore and aft as well as two nuts on each side the connect to the cross braces. I am trying to find a diagram to reference, but having no luck this morning.
Old 01-26-2013, 07:50 AM   #6
02 box s
The triangular shaped pan, part number twelve. It's the two bolts at the front.
Old 01-26-2013, 07:58 AM   #7
I had some sizes and torque spec lists for some of the bolts / assemblies here on my computer still from when I did the IMS work on your car, thought I might get lucky but not so. I remember those bolts well. Bentley Manual say anything?
Old 01-26-2013, 08:12 AM   #8
I also remember that diagonal brace could need persuading to get the rearmost holes close enough for the bolts / nuts to "catch".
Where are JFP and Schoir when we need them?
Old 01-26-2013, 08:30 AM   #9
Hey, it's cold, snowy, and I'm off today..........or at least I thought I was. In any case, they are M10 bolts on the reinforcement plate, and torque to 34 ft. lb.
Old 01-26-2013, 08:48 AM   #10
Damn, 18 minutes for the Bat Signal to work. Any idea on bolt length to help out Brad?
Old 01-26-2013, 09:25 AM   #11
02 box s
Thanks guys. I will be waiting to see if the length is available. Otherwise I will get a few different lengths and determine which is correct. New volks wheels look good. Need to get stock lug bolts for the rear. The turbo twists had 10mm spacers back there.
Old 01-26-2013, 09:32 AM   #12
Off the top of my head, I don't know the length, but they are all the same in the plate, so you can check one of the existing ones for length. But it is a M10 bolt.
Old 01-26-2013, 09:44 AM   #13
Try an M10X1.5X45
Old 01-26-2013, 09:51 AM   #14
02 box s
Thanks Jfp. i am Off to the parts store.
Old 01-26-2013, 10:30 AM   #15
BYprodriver's Avatar
10mm X 1.5 X 45mm + about 4mm thick washer
Old 01-26-2013, 07:34 PM   #16
02 box s
Got it done. Thanks to everyone for the help.
