Old 08-20-2011, 10:44 PM   #1
Top not opening
Boxster 1997 park brake lever turns dash light on and off,top latch drops windows when opened.But roof will not move with switch no noise heard.Previouse relay chatter heard when driving for have heard this for a while while not sure weather related or not.Any ideas?
hatch1517 is offline   Reply With Quote
Old 08-21-2011, 06:44 AM   #2
Porsche "Purist"
Paul's Avatar
Start with checking your fuses. D3 and less likely B6?
1987 924S. 2002 996TT. PST-2
Old 08-29-2011, 04:31 PM   #3
There are two safeties , both controlled by micro switches that can be jumped out to see if they are the issue, one is where the little hook from the top goes into the top of the windshield, the other is in the center console by the parking brake lever
In my case it was the windshield microswitch cost about $60 and took about an hour to swap out. I could slip my fingernail under it and lift it so it'd work
jakell2010 is offline   Reply With Quote
Old 08-31-2011, 03:50 AM   #4
Almost 100% certain that your problem is with one of the pair of microswitches where your interior light is at the top of the windscreen.
It is, indeed, an easy DIY job and the replacement pair of microswitches can be sourced very cheeply from the lies of eBay.
One word of warning is that the alarm sensor connector can be a real pig to fit back into the panel when you go to assemble everything and you need to be careful that you connect it otherwise you will get a toot on the horn a few seconds after locking the car with your remote afterwards, if this is not connected properly.
2001 Boxster S - 997 GT3 bodykit, Techart Wheels, Air Suspension, 2DIN stereo-GPS-Bluetooth-Reverse numberplate camera, rear speakers, Park assist, PSM, Litronic, Porsche Crests in the headrests, Rebuilt engine-IMS upgrade,Eurocup Boxster matched tube manifolds-twin high-flow cats- twin high flow rear silencers, Short-shift kit.
1999 Boxster - Xenon dip, Main and fog, Park assist, stereo-GPS-Bluetooth, rear speakers, sub-woofer
fooksm is offline   Reply With Quote
