Old 05-03-2005, 09:16 PM   #1
Please help with my CEL
Can someone please help me with these codes
CEL has come on my car, and these are the codes I got.
The symptoms are rough idling.
P1128
P1130
Thanks for the help.
JP-s-in st. louis is offline   Reply With Quote
Old 05-04-2005, 10:56 AM   #2
You're going to have to get it to a dealership or a Porsche repair shop that has a PST2 tool... it may be an oxygen sensor or a mass air fuel sensor going out.
How's your fuel economy? If the box is sucking down the fuel faster than normal, it may well be a sensor. Get it looked at asap.
Old 05-04-2005, 03:39 PM   #3
jfmillr's Avatar
Both of those codes are from your O2 sensors on your exhaust. The front two right off of the first set of CATs and near the headers. I had the same problem for a little while, but I have a VERY modified exhaust. if you are still on your stock exhaust system then I would suggest replacing both of those O2 sensors and have the codes cleared from memory and you should be ok.
www.09860.com
jfmillr is offline   Reply With Quote
Old 05-04-2005, 05:12 PM   #4
doesn't he need to replace all four? That's what I was told by my mechanic.
Old 05-05-2005, 05:22 AM   #5
jfmillr's Avatar
Not in my experience. I only had to replace the two fronts since I beleive 1128 is the one on the left and 1130 is the one on the right. After I replaced the front two(very easy to replace yourself when lifted a good foot or two, cheaper too) and cleared the stored and pending codes they have not returned in my case.
www.09860.com
Old 05-09-2005, 07:22 PM   #6
First I love the look of the car. Iwill try that when I get home in two weeks after Ireturn from a bussiness trip. Then I will post pics of my car. You will like. One more question I have the fabspped muffler but am looking for headers what do you suggest?
Old 05-11-2005, 03:09 PM   #7
Does anyone know the part # for the front two o2 sensors?
This will be for a 2000 Boxster S. Thanks
