Old 01-26-2015, 05:19 AM   #28
pjq
Wow, IMSB bolt sitting at the bottom of the bell housing flange!
Well in my case when I saw this on my car I already knew my IMSB had failed and by that stage there was oil dripping from that area. My oil sample, filter and sump had shown I had metal. I had to do a complete rebuild.
There is no oil leaking from yours, maybe your lucky. I would suggest you drain the oil (taking samples in a clear bottle), cut open your oil filter and inspect, remove you oil sump and inspect. NO metal is the only thing that is good.
