08-23-2009, 10:32 AM
#81
www.klisstle.com
Originally Posted by Jake Raby
A simple 200.00 crank pulley can easily give 10HP, but it doesn't add sound or isn't shiny.
I hear you. Once you've completed the R&D on your $200 crank pulley I will gladly install one for 10 HP! With that, I'll add whatever benefit from the 160 degree thermostat, exhaust and intake mods I've already completed, and DME reflash in the future. I'm working on the marginal gains hoping to one day add up to something significant (keeping in mind that my car is a 2.7 and not one of the larger displacement engines).
ddb
08-23-2009, 01:02 PM
#82
Aren't the Boxster Spec racers gutting OEM mufflers then running straight pipes in them? I saw a dyno from one a few years back....something like +12hp and +17lbs of torque if I remember correctly. They have NOTHING to benefit from posting claims and such,so I wouldn't find their dyno runs biased.
Found it.
http://www.boxsterspec.com/spec-boxster-talk-f2-dyno-results-for-my-spec-boxster-t715.html
08-23-2009, 01:11 PM
#83
07 Carrera S Cab
Originally Posted by ddb
2K3_Boxster_S:
Boxtaboy,
I believe the u-pipes are slightly different and therefore not interchangeable.
ddb
Interesting about the u-pipes. I guess the reason I thought they were interchangeable was because some people don't buy the full system, and instead just buy the NHP muffler alone, which I assume then they have to re-use the stock u-pipes. I guess the connection to the NHP cats might be slightly different then.
08-23-2009, 01:28 PM
#84
www.klisstle.com
That is a good point Boxtaboy. You may very well be correct.
08-25-2009, 09:07 PM
#85
scheduled dyno
Dyno scheduled Friday 8/28 9:00 am.
2003 Boxster S
08-27-2009, 05:51 PM
#86
Originally Posted by 2K3_Boxster_S
NHP exhaust is fully bolted up.
Headers with sport cats, bypass mids, Exhaust.
Bolted up and fit perfectly. no leaks from headers or mids.
All four muffler clamps that connect the U pieces from the Mids to the rear exhaust LEAK!. THERE SUPPLIED CLAMP IS GARBAGE, and you re-use 2 of the OEM sleeve clamps which also leak. $2k the exhaust should not leak anywhere.
Next: they guarantee no CELS because all 4 O2's are reconnected. Wrong, after about 100 miles. now throwing a CEL, going to check it tommorow OBII scanner. almost sure it is going to say O2. will see.
Can't wait to here there explantion for the exhaust leaks. Gd dmn ridiculous.
Trying for DYNO with AFRS this FRIDAY. DPT tuning Chesapeake, VA.
So are you still getting the CEL? What are you going to do about the exhaust leaks?
08-28-2009, 02:03 PM
#87
Results.
IMO: I would say there is a very noticeable difference in acceleration and throttle response. Take if for what its worth.
I stood behind the car with the stock and the NHP exhaust WOT. Video doesn't do it justice in the difference of sound and the quantity of hot air being blasted in my face.
Also, I am in no way trying to promote NHP. I think any decent header and exhaust set up would see the same results.
2003 Boxster S
Reason: smaller vid
08-31-2009, 07:32 AM
#88
246 whp/218TQ isn't too shabby especially without a tune. Do you still have CEL and exhaust leaks issues?
08-31-2009, 12:22 PM
#89
after cranking all 4 clamps down as far as possible. still very small pinhole size leaks, feel air coming out. I will probably remove them re-position and try again. if that doesn't work, look for some different clamps.
If I am not mistaken (some one can jump in here) I believe when I take it to Richmond, VA to authorized GIAC dealer and its chip or flashed or whatever they do and tuned that they can eliminate the P0420 CEL. or if i am wrong, i know there are some other options rear O2 bung extensions.
the CEL doesn't bother me it has no effect on the car. would be nice to eliminate it though.
2003 Boxster S
08-31-2009, 06:36 PM
#90
Rennzenn
Who is the authorized GIAC dealer in Richmond?
08-31-2009, 06:45 PM
#91
Update:
About 8,000 hard miles since May and two welds have broken on the muffler, one on the mounting bracket and the other on the heat shield.
The o2 sensor extensions have eliminated the CEL completely that appeared after about 6,000 miles with the sport cats.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
08-31-2009, 07:52 PM
#92
Originally Posted by cnavarro
Update:
the heat shield weld is only covered for 3 month's. they will repair the mounting bracket weld, but you have to pay for the shipping, probably cheaper to fix it yourself. what type 02 extensions did you use? are they all stainless?
2003 Boxster S
08-31-2009, 07:56 PM
#93
http://www.lufteknic.com/
2003 Boxster S
09-01-2009, 08:49 AM
#94
Fixing it myself, just wanted to share my experiences (both good and bad).
I purchased the ones sold by FVD - they were indeed stainless. The only thing missing were copper gaskets for the extension which we sourced locally.
Charles Navarro
09-01-2009, 12:59 PM
#95
I have the headers and bypass pipes only and dynoed a modest improvement.
What the worst thing is the supplied manifold gaskets. They are crap and will delaminate and after fixing several leaks, I just reused the stock gaskets, and no more problems noted.
2002 S
09-17-2009, 08:12 PM
#96
2K3, I was just wondering how are you liking the NHP system these past few weeks and would like an update? Are you just satisfied with it, ecstatic, or do you not care for it? Is the sound and hp gain worthwhile? Did the CEL issue cure itself or is it still there? Did you get a tune or still thinking of getting one? Thanks for the feedback.
09-19-2009, 05:56 AM
#97
Yes, I love the sound. Car is entirely more enjoyable to drive. Bottom line the car is faster and you can feel it. I will do some in car video and post later.
I will be going this route: http://www.giacusa.com/programs.php?mpid=37 for more Hp and Tq. It will be a while though. I have been busy with rental house repairs and finding new tenants. Looking at mid Oct. to get the GIAC loaded. Try to shoot some Vid tonight.
2003 Boxster S
09-19-2009, 06:37 AM
#98
Ok, sounds good. How about the CEL? Maxspeed claims their headers with cats don't cause CEL's, is this still an issue?
09-19-2009, 06:21 PM
#99
Yes, I still have the CEL. it appeared after about 100 miles. I'm not to worried about it right now, as I am about to do the ECU upgrade. If its still there after, I will get rid of it. Also the following is from MAXSPEEDS's website. They don't guarantee no CEL on all models. Check it out:
MAXSPEED
"All of our exhausts are made with Tri-Metal 200 Cells Catalytic Converters, obviously these are much less restrictive and flow more exhaust than the factory 600 or 800 Cells Catalytic Converters used by Porsche at the factory."
"After selling many of our exhaust parts that use 200 Cells Sports Cats we have noticed that on Porsche 986 All Models starting in 2003 the ECU's are much more sensitive we have been getting reports from customers who have experienced the Check Engine Light again starting year 2003, we have never seen it on Pre-2003 models but it could happen as well. Some who own 2003 Up models do not experience the Check Engine Light."
2003 Boxster S
Reason: spelling
09-19-2009, 07:34 PM
#100
You know....at the end of the day, it is still $850 - $900 bucks. I want an exhaust that is sub $500, that sounds good, looks good, weighs less, and (maybe) gives a bit of a performance increase. Besides making your own, using (for instance) a couple of Magnaflows, what are our options?
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
