Old 01-25-2005, 04:40 PM   #1
True
I have heard that Porsche is trying to milk these engines in small incriments due to the logical ceiling with the 997's 3.8L mill. They will spread out the h.p. and displacement to allow small steps just as with the original 986 the cap being 225 on my 04 2.7 (series 1 let's call it). Now with the 2nd gen motors they have upped the hp a bit. Like you said moving the obvious graph up a few hundred rpm and thus power and a bity of torque. My motors redline is 7200 and yet max power is at 6450 I think (but it really goes flat above 6k).
Ultimately if I could move that graph up to say max power at 7000 while adding headers, intake etc should get me close to 250. It would be more enjoyable to drive (pulling to redline) as apposed to falling flat at 6k. If all goes well it will be fun trying anyway.
I love tuning chat
P.S. I found out that contrary to what I thought before, Remounting the first o2 sensor to the cat (in the case of a high flow system, the one that WAS at the pre-cat) is not good. You have to extend the harness leads to the o2, that's bad. And by leaving it very close to it's original position but now on the headers (just past the collector) is the best shot and for no cel. Header wrap/jethot coating would probably help in this regard as well keeping the inside HOT for proper o2 reading. Neil @ Orton said he does this all the time with no cel's.
04 Boxster 2.7
Fletcher is offline   Reply With Quote
Old 01-25-2005, 04:55 PM   #2
if you had a set of headers tuned for 7000 revs made, programmed ecu to match, added a larger throttle body / smooth intake, then you'll see 270HP IF the valves are large enough (not sure what the stock diameter is).
that assumes 150F manifold intake temp, .25 psi manifold pressure increase, no thermal efficiency increase, lambda=.8. Just the RPM increase alone, if the ecu has enough play to tune to this RPM, would give you 253. Add everything else and you get your 100HP / L.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 01-26-2005, 09:09 AM   #3
Does anyone know the valve diameters or port areas for these cars? If we can find those, we can calculate the theoretical and most likely HP limits of these cars (without doing any serious engine work first).
insite
'99 Boxster
3.4L Conversion
Old 01-27-2005, 09:29 PM   #4
Lux
Insite,
Good stuff, man.
Fletch,
Custom mapping will yield the highest gains for sure. But even then it's still minimal gains. Dyno charts are great and all but you need to know the facts behind the numbers. Showing gains on 94 or 104 octane gas means nothing since we only have 91 in CA.
Lux is offline   Reply With Quote
Old 01-28-2005, 04:58 AM   #5
Automon's Avatar
Why only 91 in CA? I live in $hit hole USA (MI) and I can get octane up to 110, which I run in my bike but not my Porsche
Automon
Automon is offline   Reply With Quote
Old 01-28-2005, 08:04 AM   #6
We can get 100 @ some Shell stations too!
You just have to look for it. You can blend to get 93 or 94. Try this blend chart if you need it.http://members.aol.com/SteveL1994/public/OctaneChart.xls
04 Boxster 2.7
Old 01-30-2005, 11:51 PM   #7
Lux
Automon
Well, I can get 104 octane down the street at the local 76. But at almost $5/gallon I'll pass. I'm just suspicious of tuning for OBDII cars. Even Jim Conforti of BMW tuning fame said that OBDII is a ******************** and that getting 5-6hp is about it. Of course he's talking about a different car (E46 M3) but since all cars since '96 have OBDII I'd guess that we're in the same boat.
Old 01-31-2005, 07:29 AM   #8
Brucelee's Avatar
Thumbs down
Remember in CA, the state govt has fiddled with EVERYTHING! Wouldnt be surprised if 92 and up was illegal!
