02-05-2008, 07:38 PM
Motor swap options????
Everyone talks about upgrading or supercharging, turbos..... What is the largest motor one could swap into a Box? If I had the money to buy a 997 3.6 twin turbo, could I have it installed, or is there a size limit?
1999 Boxster
Triple Black (Basalt metallic)
Silver Carbon Fiber Interior,De-Ambered,Euro LED Taillights, Eibach Pro Kit lowering springs,EuroTech 19" wheels/Kumho tires,Turbo spoiler,Clear halogens
Gemballa red face gauges ..(FOR SALE)
http://i28.tinypic.com/2zzlq29.jpg
02-05-2008, 09:25 PM
I would rather do a 996 GT3 motor!
02-05-2008, 11:42 PM
Right now, into the 986, the largest displacement that is a pretty straightforward swap is the 3.6L from the 996. I believe there are a couple 986 boxsters out there with the 997 3.8L, but that is a pretty extreme and involved swap. The 987 boxster can get away with the 3.8L from the 997. You could go pretty large...and could always go big bore on a 3.6L and make it a 4.0L or even larger.. the motor itself is the same size... just playing around with the internals to get a bigger displacement
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
02-06-2008, 02:51 AM
Rennzenn
One of the size limitations with either the turbo motor or the GT3 motor is the external oil sump that these motors use. Flipped around for use in a Boxster, the oil sump would be on the left rear of the engine. The wall into our trunk is in the way. A possible solution would b to fabricate a sump similar to the coolant tank on the opposite side and plumb it in. I would absolutely love to see a Boxster with all the GT3 bits, including the motor. THAT would be an amazing automobile!
02-06-2008, 07:34 AM
The only limitation is how much $$ you have to spend.
Unlike what is mentioned below, it is no more complicated to put a 3.8 into a car than a 3.6. And no more complicated to put a 3.6 into a 2002-on car than a 3.4 into the earlier cars. It is when you start crossing the boundaries it gets complicated.
Try the search function, these questions have been answered several times.
Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
02-06-2008, 08:42 AM
Can the exhaust components from a 3.2 be used on the 3.4? ECU?
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
02-06-2008, 12:27 PM
I know the question of putting regular 3.2, 3.4 or 3.6 have been answered in the past. I was asking specifically about the turbo motors. Thank you to everyone else who understood my question.
1999 Boxster
