Old 12-20-2016, 06:47 PM   #1
Move HVAC module
Has anyone moved their heater module from above the radio to one of the cubby holes? I want to install a 2 din stereo but not sure on the move. Did a search but nothing came up.
davedeck is offline   Reply With Quote
Old 12-20-2016, 06:52 PM   #2
There is a trim piece that allows you to move it to the lowest storage bin slot.
http://www.5150motorsport.com/lower-climate-control-unit-surround-trim-996-552-339-00-01c.html
Search google. You'll get more results.
http://986forum.com/forums/performance-technical-chat/312-relocating-climate-control.html
Old 12-21-2016, 07:22 PM   #3
Thank you for the info.
Old 01-02-2017, 06:06 AM   #4
Hi did mine to fit double din Pioneer SPH-DA 120.
Easy to do, hardest thing is getting the plugs through for the HVAC unit in the lower position. But stick with it and you will get there!
Don't be fooled into buying the trim to move the HVAC unit off fleabay...they wanted £29.99 here in the uk. I got the exact same trim from Porsche for £4.60!
I have left the cup holders in as well (personal choice) lots of "kits" you can buy is only if you remove the holders. I used the old trim to fill the gap under the head unit by cutting it to suit. I have ordered a double usb lead that i plan to fit into the space on the opposite side to the cigarette lighter but am still waiting on it. Hope this helps
also added splash screen
bonesy is offline   Reply With Quote
Old 01-02-2017, 06:15 AM   #5
Splash
Splash screen
Old 01-10-2017, 05:21 PM   #6
You basically have the look I'm after. I hope i can put the Porsche logo on the screen. Thanks for the pics.
Old 01-16-2017, 11:33 AM   #7
Here's the finished project. Double USB adaptor fitted (right hand side) the other is a double USB charger using cigarette lighter.
Splash screen is easy just make sure you use correct format & size. Also on the headunit i fitted you can only use the USB 1 input to uplaod picture. Other headunits may be different you just need to check.
Next project I'm going to replace rear Bose speakers (currently not working) but use the actual unit and wire them via a 4 channel Amp.
Hope all goes well for you.
Old 03-26-2017, 02:14 PM   #8
Finished product minus trim around stereo. I lost several religions moving the HVAC wiring and poking my thumb thru the screen on the first unit while jockeying into position. This is the second stereo I had to buy. But in the end everything works. Again thanks for the advice.
