Old 03-28-2019, 04:23 PM   #441
Ciao's Avatar
Originally Posted by Ben006 View Post
Here is the complete kit :
8 left
Ben
To clarify does this kit use the original TB (74mm)? How much for the kit in dollars ($) shipped?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 03-29-2019, 04:23 AM   #442
Ben-Auto-Design
Ben006's Avatar
It does use the 74mm throttle body, which is not the original 986 TB (68mm).
Price with shipping to the US in USD is $540.
Price is based on 450€ base price, and change rate change everyday (and paypal has its own rates...) so $540 is an indication.
Ben.
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 04-09-2019, 04:15 PM   #443
Need For Speed
KRAM36's Avatar
Originally Posted by KRAM36 View Post
Our engines don't work like that. Our engines pull air into it, that's the force acting upon the direction and travel path of the air. Pedro blows air into the Distribution T, which will hit the back of the Distribution T and the wedge would have a nice impact on the way the air travels. Our engines pull air in and it rides along the side of the Distribution T. That's why the Y shape is very important and having the wedge is not.
Holy Mother of God! I was chastised over this post and 1 1/2 years later the great Jake Raby says the same thing I did about the air being pulled along the short side radius. The Y shape is the most important part of the piece, even according to Jake Raby.
Originally Posted by Originally Posted by Flat6 Innovations
No, it doesn't.
The short side radius of the IPD is where the trick is. You can't develop an intake component using a shop vac. If you do, you'll never see that what you are doing is hurting performance, or doing absolutely nothing!
With a pitot tube inserted in the intake where the splitter is installed in this photo will give zero, or very, very little velocity on the flow bench. Why? Because the air is pulled to the short side radius.
Yes, I have direct experience with this.
https://rennlist.com/forums/996-forum/944002-alternative-to-ipd-plenum-2.html#post13767949
2003 Boxster S
Old 05-12-2019, 05:05 AM   #444
PaulDash's Avatar
Is there a similar solution for the 2.5 engine?
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
Old 05-12-2019, 08:48 AM   #445
Ben-Auto-Design
Ben006's Avatar
Nope, not from me yet :/
I should do a before/after dyno comparison soon !
Well... when my car comes back from the lift and passes inspection ...
Ben
1982 928 S Euro
Old 05-23-2019, 03:14 AM   #446
so 4 years on and it still isn't available to buy or have any dyno results etc? crazy
thefunkygibbon is offline   Reply With Quote
Old 05-23-2019, 04:48 AM   #447
Who's askin'?
maytag's Avatar
It's only crazy if you think this is what he does full time, for a living.
It's not. He spends the time (and money) here and there when he can. Which isn't a lot, since he's also a full time student.
His work is absolutely first rate, and he's been very helpful to the community.
Old 05-23-2019, 08:31 AM   #448
Instead of denigrating the efforts of Ben, why not offer some suggestions of how to improve his product or development process ?
We need more talented, motivated and generous members like Ben to support the Boxster. with after market products. Snarky comments are unlikely to encourage such helpful members.
Big companies are not going to create such products for such a small, declining market so THANK YOU BEN !
Yes, I was one of his first customers and the product works perfectly and was great value.
So I am a grateful, biased user .
Old 05-23-2019, 08:35 AM   #449
Who's askin'?
maytag's Avatar
THIS. a hundred times this.
I've got Ben's shifter, and I'm looking forward to his improvement to it becoming available.
I'll likely be lined-up when the plenum is available as well.
Old 05-23-2019, 08:40 AM   #450
Porschephile
Tomikaze's Avatar
What they said. Ben’s customer service alone has me sold on his products
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
Old 05-23-2019, 11:37 AM   #451
Ben-Auto-Design
Ben006's Avatar
Thanks guys for the support
I don't think he was serious, but I think I made pretty good progress in 4 years !
The plenums are available (and carbon fiber!), there's two coming in the US with Uniwerks Design !
I'm not a student anymore, I moved back home and I'm a full time Porsche tech, and doing my stuff the rest of the time
There are three plenums left, two that will arrive at Uniwerks Design soon, and one here with me.
Ten more are coming. I'll try a new thing for the AOS tube soon.
I found a guy to dyno the car... now the hard part is to find the time !
Talking of plenum, I recently made one for my 928 !
It's just a prototype for now, but looking pretty good already !
Thanks again to all of you
Ben
1982 928 S Euro
Old 05-26-2019, 03:09 AM   #452
Hi Ben,
a little idea for improvement. The both ends of the T that lead to the hoses should have a little hump, so that the hoses can't get of the tube.
Another question: how is the T formed inside? Is there an air guidance?
Where are you located in France? I saw your video driving on Auneau Du Rin. If you live near there maybe i can help with searching a dyno near the border in Germany.
Regards, Markus
Old 05-28-2019, 11:11 AM   #453
Ben-Auto-Design
Ben006's Avatar
The previous 3D printed ones had the small humps you describe, but after trying with and without, it doesn't do much. They were good to help the porous 3D printed parts with sealing, but on the CF part, there is no problem at all
The inside of the plenum is a regular T shape, with larger radiuses to improve flow.
I didn't use a Y shape for various reason.
I live in the south, on the Riviera
Which video was it ? Because I never went (unfortunately for me ^^) on Anneau du Rhin.
I go back on track in two days ! Hopefully the gopro stays in place more than 5 minutes this time ! ^^
1982 928 S Euro
Old 05-29-2019, 04:14 AM   #454
ah ok i did not know about his background. I clicked on his website, and given that he has a company name and a proper website, the natural conclusion was that this was a company doing this. apologies for any offence, Ben.
Old 05-29-2019, 06:58 AM   #455
"i can help with searching a dyno near the border in Germany."
Well done Markus ! That is the best of this Forum - helping each other :-).
Old 05-30-2019, 11:29 AM   #456
Ben-Auto-Design
Ben006's Avatar
No worries
I do have a company, but I still work 8am to 6pm as a Porsche tech, so I can only work at making my stuff around an hour per day... that's not enough to do everything I want unfortunately :/
And add to that three project cars and time to socialize and take care of my girlfriend ^^
It's a fulfilled life ahah
Today I finally got the chance to take the Boxster on the track !
This time I came prepared and had no oil problem, so I enjoyed four 20minutes sessions of fast driving ! Keeping the engine below 6000rpm, I still kept up with way faster cars : 981S, 718, 718GTS, E46 M3 !
A wonderful day !
1982 928 S Euro
Old 05-30-2019, 11:39 AM   #457
Who's askin'?
maytag's Avatar
No worries
A wonderful day !
Which track did you go to, Ben?
Old 05-30-2019, 12:30 PM   #458
Ben-Auto-Design
Ben006's Avatar
A small track in the south of France.
"Le Luc"
I'll post a video
1982 928 S Euro
Old 06-05-2019, 12:15 PM   #459
Ben-Auto-Design
Ben006's Avatar
Hi guys !
The first two plenum have finally landed in the US !
Available here : https://uniwerksdesign.com/product/porsche-986-carbon-fiber-intake-plenum/
There're ten more coming by early July.
I have to do an oil change on the Boxster and I'm off to the dyno, I contacted the guys and we agreed on how to do it.
I'll do two passes (after driving for half an hour, so everything is already up to temp), swap the plenums on the dyno, then do two other passes. That's the most accurate way of doing it without spending a full day on the dyno...
In the future I'll get it tuned too, we might see a good increase in HP there too !
Ben.
1982 928 S Euro
Old 06-06-2019, 01:44 PM   #460
1999 base
Meir's Avatar
Hi guys !
Ben.
Very nice Ben.
and fairly priced if i might add.
keep the good work.
