Old 01-22-2015, 07:37 AM   #7
jsceash's Avatar
Originally Posted by Viper10000 View Post
I do have a few assorted triple square bits so I'm good there. I put the bearing in the freezer last night. I will try to do this project without removing the rear bumper, we will see how it goes. I am also wondering, do I really need to remove the wheel axle to hub bolts? The torque spec in the Bentley manual is 340 ft/lbs. Thats A LOT of torque. anyone remove a 5 speed transmission without doing this? I just finished my morning coffee and am about to get started. Thanks again everyone! Keep the info coming!
Agreed removing the axles totally from the hubs is not needed. Collapsing the shaft to the outside will give you all the clearance you need.
