Old 09-11-2021, 08:36 AM   #1
WTB Porsche that needs work. Looking for a project.
I am looking for a project Boxster or any other Porsche. Very open on condition and options. Located in North East Pennsylvania, but willing to travel within reason. Please contact Scott at 570-351-1888
scottweins is offline   Reply With Quote
Old 10-12-2021, 09:07 AM   #2
Hey-I I've got a silver '99 Boxster with about 125,000 miles that needs a head gasket. It could also use new suspension bushings. Other than that, it works well. I even had the A/C recharged. Make me an offer.
P.S. You can still drive the car: For the moment it's only a small leak. It burns a little antifreeze. I'm in northern NJ.
CaptSlow is offline   Reply With Quote
Old 10-12-2021, 12:40 PM   #3
1998 Boxster Silver/Red
Head gasket?
What were the symptoms? How do you know it's the head gasket?
1998 Porsche Boxster
Old 10-12-2021, 12:53 PM   #4
78F350's Avatar
Head gasket?
With M96s "Needs a head gasket." means "You're going to need to install a new head gasket after you replace the cracked head."
http://986forum.com/forums/boxster-general-discussions/81617-stalling-overheating.html
Old 10-12-2021, 01:49 PM   #5
The above posters are correct, in all the years I've run the shop, we have never seen a head gasket failure, but we have seen a lot of cracked heads; simply because the steel head gaskets are stronger than the head or engine cases. It isn't a head gasket.............
Old 10-13-2021, 02:41 AM   #6
Head gasket?
Two cylinders in the left bank create lower compression than the other four, and antifreeze came out the tailpipe from that bank when I did a pressure test on the cooling system.
Old 10-13-2021, 02:48 AM   #7
That's interesting. Is the only way to verify that by looking at the head for a crack?
Whatever the case, scottweins, it could be the head gasket or the entire head that needs replacing.
