Old 07-17-2016, 11:32 PM   #1
largest oil -water heat exchanger that fits?
I would like to know which cooler is the largest that will fit under the 2.5l intake runners. Is there anything bigger than the Boxster S cooler?
Bebbetufs is offline   Reply With Quote
Old 07-18-2016, 02:29 PM   #2
No, the S cooler is as big as you can go before hitting the intake runners.
Old 07-18-2016, 03:15 PM   #3
S cooler ordered. Now I need to make a gt3-style s-duct for the centre radiator.
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
Old 07-18-2016, 07:25 PM   #4
madmodz's Avatar
The boxster S water lines are also physically larger then the regular boxster. There was a comparison done on this forum.
madmodz is offline   Reply With Quote
Old 07-19-2016, 08:33 AM   #5
steved0x's Avatar
Random thread hijack - I have wondered if a fan pack could be added to one side of the oil/water heat exchange to force some more air around it to help shed some heat. I've never seen one in person so can't tell how deep those ridges go - if they would provide any surface area to shed heat, or if it would be negligible.
Old 07-19-2016, 11:54 AM   #6
rastta's Avatar
My engine cover has been modified to include two large fans in a shroud built above the engine. It is operated by a simple toggle switch on the dash. It works great to cool the engine and the oil cooler. Pics at home so I can't post em right now.
rastta is offline   Reply With Quote
Old 07-19-2016, 12:40 PM   #7
steved0x's Avatar
Very interesting, I would love to see a pic sometime. No rush
Old 07-20-2016, 07:31 AM   #8
rastta's Avatar
Heh - I looked for some pics last night - and only have a top view - which doesn't show the fans. I'll snap some next time I have a chance as the car's in the trailer waiting to get an alignment.
Old 07-20-2016, 02:40 PM   #9
Just be aware that in the event of an engine fire you now have created an effective chimney directly into the cockpit. You have nothing protecting your head from the flames....I don't want to put down the idea, it will probably work well, but I think you shuld be aware of the risks.
1990 944 Turbo
Norway
Old 07-20-2016, 03:00 PM   #10
The main lines or just the front lines? I suspect the S uses the same water necks for the the outle and inlet to the engine so the difference for the main lines can't be huge. Is the difference in the Y at the front?
1990 944 Turbo
Norway
Old 07-20-2016, 04:24 PM   #11
rastta's Avatar
The car does have an on board FE-36 fire suppression system with nozzles in the interior and engine compartment - but so noted.
Old 07-26-2016, 03:20 PM   #12
Good idea to have such a system. I should have known you had thought about this.
1990 944 Turbo
Norway
