Old 01-17-2007, 11:25 AM   #21
I think the suspension was like $2700-2800. Then the labor, alignment, and corner balance was another $700-800. Then tax was another $300-320 or so.
I could have gone with the PSS9s, but I wanted something a little higher end. I autocross the car and was looking for that extra edge over all the cars with PSS9s.
Not overpriced in my book. Yes I could have gotten the suspension for cheaper online, but cheaper is not always better. I purchased them and had them installed from one of the few distributors in the US. The customer service was top notch, and that itself is worth more $$$ in my book.
-David
1996 993TT - current
2001 Boxster S (sold)
19" SSR GT3 - Cross coilovers - Custom Magnaflow exhaust - B&M Short Shifter - EVO intake - GT3 Seats - Hardtop
http://www.emeraldcitycustoms.com/images/box2.jpg
1986 Carrera (sold)
David_J is offline   Reply With Quote
Old 01-17-2007, 11:42 AM   #22
I'm surprised that the way you're addressing what you describe as the "big gap between the tires and fenders" is by lowering the car rather than getting 19 inch tire/rims, which I think is what Jeff Squire was getting at. My previous base 987 had the 17" OEM rims and that gap you're alluding to was horrendous (not to mention that the 17" rim design is pretty uninspiring). I would agree that while not as bad, the gap is still present with the OEM 18" rims you have. The 19" (Carrera S) wheels on my current car eliminate that gap and make the car appear lower (although the rim design remains uninspiring).
The 987 wheel wells are designed to look flush, and therefore more appealing, with the 19" upgraded tires that Porsche sells for that model, just as the 986 with 16"s looks like poo when compare to the upgraded 18" wheels.
PASM, which I have, lowers the car by 10mm (just shy of half an inch) and anyone who tells you that they can spot a car with PASM from the outside is pretty much FOS (a non-Porsche acronym), so I don't think lowering your car by that amount will achieve the effect you're looking for.
As far as how the car feels on the inside, compared to its competitors, Im curious what your reference point is, as both the SLK and Z4 "feel" like you're riding higher, than in the 987.
06 987S- Sold
05 987 5-speed - Sold
06 MB SLK350- Lease escapee
SD987 is offline   Reply With Quote
Old 01-17-2007, 12:07 PM   #23
Getting the 19" rims will not increase the diameter of wheel (the rim + tire combo), as 17", 18" and 19" rim + tire combos produce wheels of about the same overall diameter. Actually, the diameter of the 18" wheels (rim + tire) is slightly larger than the diameter of the 19" wheels.
The only way to fill out the gap without lowering is by using a larger diameter wheel. This means getting larger profile (vertically fatter) tires than recomended for each particular rim size. This will actually raise the car a bit but will fill the wheel well better. This will also affect the suspension, and the speedo and odometer measurements as they have not been calibrated for these larger diameter wheels.
Z.
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
Old 01-17-2007, 01:12 PM   #24
Thanks for all the ideas.
I went onto bilstein's website and there are some adjustable suspensions w/ shocks & springs for the boxster (not sure if it has coilovers) or not, but there was also no price on the site.
The idea of 19" wheels and fatter tires seems logical, but I worry about adding too much unsprung weight. Lightweight 19" wheels will be VERY expensive!
Can I buy and use coilovers independently or do I need to replace multiple suspension parts?
Adjustable ride height does make sense. I wish I had PASM but I don't :-(
Miss my Boxster
Bavarian Motorist is offline   Reply With Quote
Old 01-17-2007, 01:30 PM   #25
Bilstein PSS9 is a complete adjustable height solution. I have heard many good reviews about it and it is widely used by Porsche enthusiasts. It costs about $2k + installation, more or less.
Old 01-17-2007, 01:43 PM   #26
Interesting debate and no one answer will fit all owners. As I see it, there are really only 3 reasons to lower the car, each has it's own merits and drawbacks:
  • A. To make a better Track car by lowering the CG.
    B. For the aesthetics, to remove any wheel well gap.
    C. It's the one area where you haven't modded the car.
For A., lowering the car also lowers the CG, decreases body roll and weight shift, which reduces the inside wheel's potential for lift. But, suspension travel is also reduced altering the ride quality. Notice I didn't say negatively altering ride quality because this is somewhat subjective. What some may deem too harsh or jarring, others appreciate as more feedback or tauter feel.
B. while reducing the wheel well gap, will also alter ride quality in addition to reducing ground clearance, which on a primarily street driven car could have some inherent negatives (which one may well be willing to assume) such as grounding out or not clearing obstacles. Be sure to re-aim your headlights if you do.
C. for some people is an obsession. They are never done. So, after Wheel, Tire, Intake, Exhaust, Interior, Sound System and the like are completed, this may be the only remaining area to be modded. Perfectly OK, it's their car, their money; Porsche even recognizes owners desire to customize their car(s) and encourages it.
There have been a few reports of people lowering the car and regretting the results, while many others praise this mod. The smartest thing is to objectively evaluate what you want from the car and how you use it. This may mean that lowering doesn't make sense for you, or maybe it does. If it does, people will often use any, or some combination, of all 3 reasons to justify it.
For me, it doesn't make sense to do it (already have 18" Turbos and am satisfied with it's appearance, don't Track this car), but it did make sense for one of my other cars (for some of each reason - A., B., & C.).
Happy Motoring!... Jim'99
Old 01-17-2007, 04:55 PM   #27
Based on comments from another forumite and the posted measurements of lowered vs stock cars, I am about positive my S was lowered by the original owner. Is there an easy way to visually verify what was done, i.e. any sort of identifying marks on springs, etc? Is this something that the car would have to be on a lift to look at? I guess the obvious answer would be to try to track down the original owner and ask him...
dmcutter is offline   Reply With Quote
Old 01-17-2007, 06:12 PM   #28
Okay, that was easy. Googled the original owner and called him. Sho nuff, Eibach springs. Dang, there's like NOTHING left to do to my car except the turbo or supercharger....
Old 01-31-2007, 12:11 PM   #29
Just a question:
Can I lower my car w/ just lowering springs? Do I NEED the entire setup?
If so, I would like to do this. They aren't that expensive!
Miss my Boxster
Old 01-31-2007, 12:27 PM   #30
boggtown
Posts: n/a
Well... You could...
You could also take a blow torch to the springs to collapse them, thatd be "cheaper" if thats what your looking for. Oh ya, they wouldnt work any more and itd be like driving a cinder block.
Old 01-31-2007, 12:30 PM   #31
Well, is it realistic to just use the springs? I guess that's a better question.
Miss my Boxster
Old 01-31-2007, 12:33 PM   #32
boggtown
Posts: n/a
Ya, people do it all the time. You wont get the same benefits as a full coil over suspension, but if you dont track the car you wont mind too much. The reasoning against only getting springs is that if your gonna blow $600 bucks on install, you might as well pay another $700 for the shocks.
Old 01-31-2007, 12:35 PM   #33
Do you recommend just saving a couple hundred more and getting the entire pss9 suspension?
I found it for 1795 I think...
Miss my Boxster
Old 01-31-2007, 12:37 PM   #34
boggtown
Posts: n/a
Yes, it may take longer, but it will be done. For good. I learned half assin things just makes you do it over and over again, in the end, costing more than it would have originally. Plus, by selling your whole suspension instead of just your stock springs your likely to have more buyers.
Old 01-31-2007, 12:55 PM   #35
lwc
I would like to lower mine, but the roadways where I travel just won't allow it. Instead I added 7x14mm spacers and the look is improved. The wider stance creates a bit of an illusion so it's not a bad compromise . . .
lwc is offline   Reply With Quote
Old 01-31-2007, 01:09 PM   #36
Do you have spacers on the front also? Hows the cornering with them on now?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 01-31-2007, 01:49 PM   #37
lwc
7mm on front, 14mm on rear, I haven't been able to tell much difference from standard as far as cornering goes. Probably a slight amount of improvement just because of the slightly wider track. I think it looks a lot better though, which was my main goal.
Old 01-31-2007, 02:16 PM   #38
Originally Posted by Bavarian Motorist
Just a question:
One drawback to using only springs to lower the car is that the geometry is not preserved. You will increase the negative camber which will increase the car's tire-eating abilities...
Old 01-31-2007, 02:21 PM   #39
Any drawbacks to using spacers like lwc did?
Old 01-31-2007, 02:45 PM   #40
Generally not, but there are a couple of caveats.
  • Not all spacers are created equal. Be sure to use quality hub-centric spacers. The cheaper ones are often not machined to exacting tolerances and vary considerably. This can induce a tire imbalance. Also, they must be installed carefully, it's very easy to introduce some variation just by installing them willy-nilly.
    Keep the spacers to no more than 17mm. Going wider effectively softens the Spring Rates because you are essentially lengthening the lower control arm and it's angles. Too wide, and again, you induce greater negative camber. It will also change your steering response at the limit, something which may cause someone unfamiliar with the feel to improperly respond with negative consequences.
    Finally, whenever doing any work to the Wheels, Tires, Suspension, you need to get a full 4-wheel alignment. Alignment isn't as permanent as many people seem to think. Hit one good bump or Pothole, and you'll likely throw it off. Everytime I auto-x my cars or track my formula vee, the alignment is altered. This needs to be done much more often than many people think to remain spot on. On a Street Car, it should be done annually, or whenever doing any work to the areas mentioned above.
Hope this helps...
