Old 03-23-2025, 12:04 PM   #1
No start.. no crank... no nothing
My 99 base started only in neutral. I moved it 10 feet because of a summer storm. After the bad storm, went to move it back, it started and ran real rough. I hit the gas, it made a bad sound and died. Now, it won't even try to start. Battery is 100% charged. But no start, no crank, nothing. Any ideas?
Randywhatson is offline   Reply With Quote
Old 03-23-2025, 12:39 PM   #2
Look under the driver's seat for the alarm/immobilizer and look for wetness; if it is wet, that is your problem.
Old 03-24-2025, 08:22 AM   #3
My no-start last week was my clutch switch. Bypass the clutch switch to eliminate that. I found a really good youtube video for troubleshooting no-start that I saved, because it did a great job of walking through no-start troubleshooting.
https://youtu.be/ZSmehtE8Ctk
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 03-24-2025, 04:34 PM   #4
You may want to check where the positive cable from the battery attaches into a plug on the firewall
Old 03-25-2025, 01:16 AM   #5
Originally Posted by professorman View Post
That's nice, cheers, I saved it as well. I wonder why he does not check fuse C3, because that is the immobilizer. The immobilizer itself has a fuse as well, you need to disconnect the battery first an then check that fuse. You at least have to loosen and tilt the seat for easy access....
Old 03-25-2025, 06:41 AM   #6
does immobilizer prevent start ? as in endless cranking ? or does it completely disable the starter circuit ??
i always thought it just disabled the car from actually starting , but fortunately have never had to find out.
theiceman is offline   Reply With Quote
Old 03-25-2025, 07:35 AM   #7
You are absolutely right, it prevents starting but won't avoid cranking! My bad.
Old 03-27-2025, 10:05 AM   #8
Thanks for the help so far. I watched the youtube video. None of that helped, unfortunately. I now think that it's the park/neutral sensor. Like I said, I had to resort to starting in neutral. Then nothing. I guess it finally failed. Any videos/tutorials on replacing it? I imagine I'll have to remove the shifter housing?
Old 04-05-2025, 11:38 AM   #9
Gigi's Avatar
The starter failed me twice.
The starter failed me and I replaced it but never had what you described. 986 Boxster - a dead or failing starter motor can manifest as slow cranking, a clicking noise when trying to start, no response at all, intermittent issues, or a burning smell from the engine bay.
Gigi is online now   Reply With Quote
Old 04-05-2025, 12:13 PM   #10
Your problem began after a major storm according to your initial post, you need to start looking at the immobilizer under the driver's seat, a major failure point when these cars get wet inside..............
