Old 06-03-2024, 02:09 PM   #1
98 Arctic silver 986
tommy583's Avatar
Middle oil filler tube removal
Hi all,
What is the best way to remove the middle oil filler tube? I am having trouble with the clamp that is near the fire wall. I tried to get to it from the bottom while laying on my back, with the car on a quick jack. No way I can reach it like that. From the top I can't seem to get my clamp tool onto the clamp. I see they all go into the trunk, is there a way to get to the clamp from the trunk? Or will I have to take the whole coolant reservoir out to go this route? Thanks in advance.
tommy583 is online now   Reply With Quote
Old 06-03-2024, 02:30 PM   #2
A cable drive clamp tool helps a lot .
Old 06-03-2024, 02:36 PM   #3
tommy583's Avatar
That is what I'm trying to use. I guess I'll just keep at it.
Old 06-04-2024, 08:50 AM   #4
Patience is the key. Walk away when necessary and come back to it when ready. This was essential when I replaced the coolant tank. Patience along with JP’s tool suggestion will get you there. Good luck.
Jgkram is offline   Reply With Quote
Old 06-04-2024, 07:39 PM   #5
elgyqc's Avatar
I found that I had to rotate the clip to a position where I was able to get it with the clamp tool. I think I used a long screwdriver lubricated with patience and colourful language.
Grant
