Old 02-14-2024, 10:41 AM   #1
LoneWolfGal's Avatar
Frunk light microswitch
Danged if I can find it. Maybe I'm going blind.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
Old 02-14-2024, 11:46 AM   #2
It is built into the latch assembly....................
Old 02-18-2024, 11:15 PM   #3
Thanks. That being the case, will the switch's "on" status be deactivated if the hood is closed but not completely latched?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
Old 02-19-2024, 05:17 AM   #4
You need to ask Porsche style...
"Will bulb's Off status be Activated if hood is closed but not 100% latched?"
Generally speaking, you are correct by engineering design.
That said, you can always disconnect plug at latch and thus proverbially short circuit if there should be issues w latch switch at that location.
Good luck
"Cool Prius!"
- Nobody
Old 02-19-2024, 08:55 AM   #5
Yes, I definitely need to rephrase my question. Here goes: If the hood is closed, but not latched, does the frunk light remain on? The reason I ask, it's a pain to uncover the car to gain access to the lever on the door sill to open the frunk. If the hood is closed, but not latched, I can simply lift the front of the cover, trip the latch lever, and I'm in. A good plan, but only if the hood doesn't need to be tightly closed and latched to shut off the light. I considered asking someone to shut me inside the frunk so I could see for myself, but something about that plan bothered me.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
Old 02-19-2024, 10:45 AM   #6
Moderator
Put your smart phone in there while it’s recording video
Bill Ladd is online now   Reply With Quote
Old 02-20-2024, 05:05 AM   #7
Registered Member
Not sure about your ?2000?, but the power controller on my 2003 will shut that light off after some period of time. Maybe an hour, I’ve never actually timed it. Easy enough to verify for yourself…
tcoradeschi is online now   Reply With Quote
