Old 02-14-2023, 11:56 AM   #1
Shifter
I am trying to learn about my recent 1999 Boxster. I was looking into the shifter today and considering a short shifter mod. Mine looks modded. .It has a set screw that is very hard to turn and the leather it snuggled onto the knob with zipties. It seems the knob will not just pull off. I am curious if has been cut down. It is a tad over 6" long from the top of the white piece to top of the knob. Not sure if the knob is original. How tall is a stock shifter?
wiebuschk is offline   Reply With Quote
Old 02-14-2023, 12:56 PM   #2
1998 Boxster Owner
I don't remember if mine had zip ties, but the shifter looks stock to me. I have the same shift knob as well.
Benitom is offline   Reply With Quote
Old 02-14-2023, 01:27 PM   #3
Multi-Boxer Driver
Deserion's Avatar
Generally the knobs are friction fit. I may have smacked myself in the face removing it, I can’t recall.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 02-15-2023, 10:10 AM   #4
Registered Member
Yup! Pull *really* hard. I think some early knobs may have a set screw as well.
tcoradeschi is offline   Reply With Quote
Old 02-15-2023, 10:19 AM   #5
That looks like a stock shifter. I just installed a short in my ‘04 S & it’s completely worth it. Most short shifters I’ve seen have an aluminum body & my stock one had the same plastic body as yours does. I did have to take a dremel to the black plastic frame or mount in order to access reverse.
The difference is night & day. The distance your hand travels is about half what it was & for me at least gears are more defined (especially 3rd)
paulb is offline   Reply With Quote
Old 02-16-2023, 04:37 PM   #6
98 Arctic silver 986
tommy583's Avatar
That is a stock shifter. It is also a stock shift knob and boot. I've had the exact same set up in 2 different Boxsters. You will need to loosen the Allen bolt to remove the knob and boot. The more basic knob and boots don't have the bolt and can be just pulled off (with a lot of force). The boot and knob will fit on any short shift that you would purchase.
tommy583 is online now   Reply With Quote
Old 02-17-2023, 06:38 AM   #7
Thanks for the input gays!
Old 02-19-2023, 01:24 AM   #8
That's really interesting. When I swapped out my shifter, I thought it was interesting that the post was blade/oval shaped and not a round shaft like every other shifter on the planet. I wonder why porsche went back and revised the part?
Sent from my SM-N975U using Tapatalk
Old 11-15-2023, 07:48 PM   #9
Registered Member
Which short shift kit did you install?
My 2004 S doesn’t shift very crisply, especially 3rd gear and I want to upgrade.
muledog is offline   Reply With Quote
Old 11-16-2023, 06:23 AM   #10
A 986 S's Avatar
I installed one of Ben's ball bearing short shifters and really like it. Seems to make shifts quicker and more precise..
The exact shifter that I have doesn't appear to be available but this looks like his current version - https://www.uniwerksdesign.com/product/bens-porsche-996-986-short-shifter/
Photos of my install here (near the bottom of the page) - https://rx19jones.wixsite.com/projectboxster/projectboxster2
Cheers - dj
2002 Boxster S Orient Red Metallic / Graphite Gray
https://rx19jones.wixsite.com/a-986-s
A 986 S is offline   Reply With Quote
Old 11-16-2023, 11:02 AM   #11
There are a lot of options. There are the cheap short shift kits from China that you can find on eBay and other places. I believe in the early days, Ben used to buy these and modify them. Ben sells kits to modify your shifter too. I ended up putting a 987 shifter in my 986 - which offers a slight reduction in throw.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
