Old 12-28-2022, 05:26 AM   #1
Thoughts on powder coating calipers
I have a 2004 Boxster special edition, so the calipers are matte silver. The back calipers look good, but the fronts seem to have a buildup of dust that I can't get off. Plus, I would prefer "shiny" calipers like a Boxster S to the matte finish they have now.
I have painted calipers in the past, but I'm wondering if anyone has experience with sending the calipers off to be powder coated. Any recommendations for a shop?
s_wilwerding is offline   Reply With Quote
Old 12-28-2022, 07:48 AM   #2
seningen's Avatar
wouldn't you now have an issue with the piston bores -- you'd have to either block that off, or hone them out.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 12-28-2022, 07:51 AM   #3
I think most powder coaters block them off.
Old 12-28-2022, 09:42 AM   #4
I have sent motorcycle brake calipers to get powder coated many times. Just make sure they block off everything where you don`t want sand gotten into and remove everything that won`t withstand high temperaure.
Old 12-28-2022, 08:56 PM   #5
I did mine. You should rebuild them and the inner seals are a bit of a bear to get. Make sure whomever does it knows how to handle and mask calipers. I had to have mine stripped and done again. Do they look awesome? Yes! Was it expensive and a ton of work and back and forth yes as well.
badsurfer67 is offline   Reply With Quote
Old 12-29-2022, 10:01 AM   #6
I had the calipers repainted, he re-did the lettering and then clear coated everything. I found new emblems for the wheels on ebay.
PS it is funny how I post things here and they never appear ? Happened multiple times ... I guess only certain posts are deemed acceptable ?
Herbert W. Hamber is offline   Reply With Quote
