Old 10-15-2022, 09:30 AM   #1
Help I've disconnected the battery and closed the bonnet
I've tried powering via the red fuse in the fuse box and earth but nothing happens. Any ideas please
kencharlton is offline   Reply With Quote
Old 10-18-2022, 10:59 AM   #2
2002 Boxster S
Lots of youtube videos on this. You may not be getting a good ground if you're using the terminal in the fuse box and it doesn't work. I couldn't get a ground on the metal toward the front of the car then tried the chrome metal door latch on the rear side of the body in the driver door opening. Got a ground and the frunk open.
2002 Boxster S 6 spd manual Arctic Silver
john12312 is offline   Reply With Quote
Old 10-18-2022, 11:09 AM   #3
Coaster's Avatar
same for me. Had to move ground around a bit to find the sweet spot.
Coaster is online now   Reply With Quote
