Old 05-04-2021, 11:39 AM   #1
Inner door pull - microswitch removal
I did a search and while there are a lot of threads on microswitches and window regulators, I wasn't able to find the answer to this...
How do you remove the microswitch in the inner door pull assembly?
Background - I have determined that I need to replace the microswitch in the inner door pull that is on the passenger's side. I was able to find a complete inner door pull assembly at a junk yard and need to remove the microswitch from it and put it in my car. The door pulls are different colors so I can't just use the entire assembly. I know it is possible to remove the microswitch as Pelican Parts sells a replacement - 996-613-123-00-OEM
I don't want to break the microswitch figuring this out. Any help on which direction to pry it out (or if there is a retaining clip that I'm not seeing)?
elav is online now   Reply With Quote
Old 05-04-2021, 11:57 AM   #2
difficult to describe. if you take the door panel off, just follow the wire and gently pull it out. Might need a pick to help release it.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 05-04-2021, 12:15 PM   #3
Thanks - I actually pried it up by placing a screw driver blade between the handle frame and where the electrical connector attaches to the microswitch. Popped right out.
Old 05-05-2021, 03:49 AM   #4
flouese's Avatar
My pax side door fail periodically fails to unlock or be opened from the inside. Are you having the same issue?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 05-05-2021, 07:36 AM   #5
that has nothing to do with the microswitch
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 05-05-2021, 02:16 PM   #6
No, my window doesn't drop when I attempt to open the door from the inside. I have ruled out the window regulator as it works from the outside handle.
