Old 04-03-2021, 07:33 AM   #1
Word of wisdom...
Dont bother
Realistically though it's just easier to spray a little white grease in it, put key in and turn the key a few times. No need to really take it out.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 04-03-2021, 07:46 AM   #2
The key tumblers don't really have many issues.
Just use some spray lube and spray it in the key slot.
The locking mechanism for the steering and the ignition electrical switch are what usually have the issues.
Old 04-03-2021, 07:58 AM   #3
Rob175's Avatar
Thanks!!....I just went out to the garage and using a "dry lock spray" made for cleaning and lubricating locks I sprayed the hell out of it then ran a pipe cleaner through it.....the pipe cleaner came out pretty clean, just wet. Then I used the key and all seemed fine. I could definitely hear the "clunk" when I pulled out the key, which I assume is the steering wheel lock engaging....and the radio shut down. as it should. (I always keep the radio on when driving).
Whew.....I really didn't want to pull the tumbler out....thanks!
Rob175 is online now   Reply With Quote
Old 04-03-2021, 07:56 PM   #4
yes the clunk is the steering lock
Old 04-04-2021, 06:05 AM   #5
Rob175's Avatar
Not sure if my sort of "flooding" it with lock lube did the trick but the 23 year old lock works great now and the steering wheel lock "clunk" sound in much more "distinctive" than before. ALL good!
