Old 03-23-2021, 06:52 AM   #1
98 Arctic silver 986
tommy583's Avatar
Clunking rear
Ok so it has come time to remove the car from it's winter cocoon. Driving it yesterday refreshed my memory of some strange noises. A clunk from the rear end over small bumps for one. The most likely cause of this I would think are the track bars. The front end also makes a few weird noises. What goes out first in this area? Drop links? The car also needs new tires. Even though I may end up getting a newer Boxster this year, I still need to address these issues. I may keep it or I may sell it. Either way I need to make it better. What are the most common front end noise makers? I'd imagine with 150K it would make sense to replace everything, but I don't have the cash for that.
Thanks,
Tommy
Old 03-23-2021, 07:31 AM   #2
check the shocks & struts to see if they are leaking. That many miles they are going to be bad most likely. Other thing it could be would be the sway bar end links & bushings which are cheap & easy to do.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 03-23-2021, 09:13 AM   #3
You're spot in - track arms in the rear, drop li ks up front. Although control arms can go clunk too. Stl is right - check sway bars and bushings. Struts too if it feels like there's a lot of play in the picture, mine in has 47k but my struts were so far gone that even the bump stops had disintegrated.
Sent from my POCOPHONE F1 using Tapatalk
Old 02-06-2022, 07:25 AM   #4
2001 Boxster S 6sp
Chboro's Avatar
Getting ready to do my rear trailing arms. Going to check that strut pinch bolt as well.
Wondering though - just which end of the trailing arm is causing the clunk?
2001 Porsche Boxster S
2022 Hyundai Santa Cruz
1983 Alfa Romeo Spider (PO)
1969 Morgan 4/4 1600 (PO)
Chboro is offline   Reply With Quote
Old 02-08-2022, 08:19 AM   #5
FoFoJoe
FoFoJoe's Avatar
Just to add a data point here, I think I have the same "clunk" that OP described. Mine happens at low speeds on bumpy driveways/uneven roads. In researching the cause before, the rear trailing arms seemed to be the culprit. It never annoyed me enough to fix it though....
I am not sure which side would cause the noise on the trailing arm, but I'm sure its from one of the bushings thats built into the arm.
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
Old 02-08-2022, 06:30 PM   #6
I had the same problem. First I replaced the rear track arms; maybe helped a little bit. Then the drop links. Maybe helped another little skosh. But the real solving of the problem, for me, was to basically replace all four corners' control arms, as those bushings were worn from age. I also did the tie rods up front while I was at it. It was definitely night and day - ain't perfect, as I do think new shocks would help - but it took care of most of THAT noise. (Now if I can only figure out how to tighten the top/body panels so they don't rattle/squeak when going over poor roads...)
safesaxbdd is offline   Reply With Quote
Old 02-08-2022, 09:58 PM   #7
@tommy583 i fixed the rattle by putting the top down.
@safesaxbdd, i replaced the front control arms, outer tie rods, shock mounts, bump stops, rear track arms and all shocks. which brings the ride to almost factory new and no noise.
moosport is offline   Reply With Quote
Old 02-08-2022, 10:46 PM   #8
What brand control arms are people buying? Replacement bushings can be the same price as a new one (if not Porsche brand).
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 02-09-2022, 06:02 AM   #9
elgyqc's Avatar
Has anyone tried Meyle suspension parts as sold on eBay? They supposedly are German and from what I have seen in online discussions they can be as good as other after market parts.
Grant
Old 02-09-2022, 08:42 AM   #10
I bought TRW trailing arms off of Amaz a few years ago...great price and OEM. Clunking gone and not hard to install.
dghii is online now   Reply With Quote
Old 02-09-2022, 09:33 AM   #11
1998 Boxster Owner
@tommy583 if funds are tight - i recently changed sway bar links with TRW links and changed sway bar bushings with OEM porsche bushings. Total was about $200.00 Aftermarket bushing will be less. I need shocks and this will hold me over in the meantime. Major difference in handling. But I still feel large bumps cause shocks are coming to their end. I am at about 79k miles. (1998 Boxster)
Benitom is offline   Reply With Quote
Old 02-15-2022, 04:00 PM   #12
tommy583's Avatar
Hi guys. I still never got around to fixing the clunk. I just put the top down like someone above said. Now I have the clunk in the rear and a squeak on the right front. Bumps make it squeak and turning right makes it squeak more. Looks like I will need to take care of these noises this spring.
