Old 10-23-2006, 08:15 PM   #1
wax/polish removal from clear bra edge
Ok...i admit i was lazy when applying the wax ......but i covered the edges of my clear bra and now the edges stand out.....big time!
Anyone have a good idea on removing this.... i do not want to fray the edge, but just rubbing along the edge doesn't seen to get it.....
RD
Woof Woof!
RONDOG
2005 987S
BLK/BLK
PASM
SPTS CHRONO +
PCM w NAV
19" CARRERA S
http://i112.photobucket.com/albums/n...P4724Large.jpg
Rondog is offline   Reply With Quote
Old 10-23-2006, 08:23 PM   #2
Send a message via AIM to Travis
Just a thought, but have you tried a hair dryer to heat it up along the edge and then wipe away from the seam?
Travis is offline   Reply With Quote
Old 10-23-2006, 09:23 PM   #3
Perfectlap's Avatar
detailcity.com sell something called wax buster which come in one of those shoe polish type applicators with the foam on the tip. carefull around there, you don't want to lift the edging. Best to use painters tape on those edges.
BORN: March 2000 - FINLAND
Old 10-24-2006, 03:41 AM   #4
Rondog, I haven't tried this myself (I barely have any edges on my clear bra) but I remember reading somewhere that a Q-tip dipped in some solution may work. I don't remember the solution but you could try anything that removes wax. High concentration car wash solution, perhaps? Would be curios to learn what's best, myself.
Sorry I couldn't help more.
Z.
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
Old 10-24-2006, 06:37 AM   #5
rondog, I haven't used this but you could give it a try:
http://www.topoftheline.com/trim-cleaner.html
A detailer at Rennlist recommended it for removing baked-in wax residue.
Z.
Old 10-24-2006, 07:34 AM   #6
bmussatti
Guest
Posts: n/a
Rondog, here is how you do it. This is the same issue we experience with the edges on the stone guards near the rear wheels. I "lost" my first Concours (took second place) because the Judge scored me down for having dirty edges on the stone guards.
Buy some WURTH citrus degreaser (www.wurthusa.com). Dip a Q-Tip in the solution (100%). Trace the edge with the wet Q-Tip, and wipe the edge with a clean, white, 100% terry cloth towel. You may need to repeat these steps 2-3 times to loosen and remove all of the wax.
I have done this now about 3 times with the edges on my stone guards, and everything looks great!
Old 10-24-2006, 07:36 AM   #7
bmussatti
Guest
Posts: n/a
Rondog, I posted this tip a few months back:
http://986forum.com/forums/showthread.php?t=6529&highlight=triangular
Old 10-24-2006, 06:11 PM   #8
mussatti---You ARE the man!
thanks for the advice.... my order to Wurth is on it's way....
Thanks agian to all responders!
RD
Woof Woof!
RONDOG
2005 987S
BLK/BLK
PASM
SPTS CHRONO +
PCM w NAV
19" CARRERA S
