Old 08-20-2020, 04:43 PM   #1
Manual transmission aluminum cover
Hi all,
Longtime reader, first-time poster. I've got a 2008 Boxster 987 (I know this is the 986 forum, but the cars are very similar. And you guys have better information here than other sites). I replaced the 5-speed manual transmission mounts on my Boxster today, and that all went well. But I'm having serious troubles trying to get the aluminum cover pan back on. The bolts just don't seem to align, so I'm assuming things shifted slightly. I've already torqued the bolts on the new mounts, would it be helpful to loosen them back up? Any other ideas? The car is up on a scissor lift, so all four tires are suspended and hanging and have been since before I started the replacement. All help is VERY much appreciated! Thanks!!!
jamesa914 is offline   Reply With Quote
Old 08-20-2020, 05:09 PM   #2
Who's askin'?
maytag's Avatar
Originally Posted by jamesa914 View Post
Hi all,
It's my understanding that the 987 rear-end is quite similar to the 986. So you;re probably talking about the triangular-shaped alu 'pan' / brace that bolts front & back, and on the two uprights. And it's those latter bolts that you can't line-up, right?
When you lifted the car and let the wheels & suspension droop, especially for any length of time, those uprights will shift, usually (maybe always?) APART from each other. Many of us find that a ratchet-strap between the uprights will bring them back together enough to get the holes to line back up.
If I've misunderstood the problem you've described, then ignore ALL of this.
Old 08-21-2020, 01:12 PM   #3
Ciao's Avatar
So if raising the rear to work on exhaust its better to use car ramps?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 08-21-2020, 03:40 PM   #4
Who's askin'?
maytag's Avatar
I don;t use ramps for ANYTHING. They're nothing but in-the-way for me. I remove that triangle alu plate all the time. I jsut plan to put a ratchet strap on the uprights to refit it.
Old 08-21-2020, 04:03 PM   #5
I do use the ramps on the rear axle...
As a first step to raise the rear end, then I use a 4x4 with the floor jack to raise it further up and to position the jack stands under the car jacking points..
This has worked out for me, and will do it until I can afford a lo-jack..
PS: I have never required to use the straps because I had always removed the wheels before removing the aluminum triangle (no weight on the suspension with the triangle removed..)
Old 08-21-2020, 05:21 PM   #6
Ciao's Avatar
Great Tip!
Old 08-21-2020, 08:18 PM   #7
That was exactly the problem, and thanks for your tip. The ratchet strap (and a little bit of brute force) enabled me to get the triangle reattached. Everything is put back together, and I just got back from a test drive. Car is much smoother with new tranny mounts. Thanks!
Old 08-22-2020, 10:33 AM   #8
James, you may want to check that the alignment on the rear axle is within spec..
Old 08-22-2020, 11:16 AM   #9
Who's askin'?
maytag's Avatar
That's a good thought, but I've never, ever, had it change from removing and the replacing that alu cover / brace. The first couple of times, I had it checked right after. Since then, I've quit worrying about it.
Old 08-23-2020, 05:19 PM   #10
Ciao's Avatar
Is it possible to remove exhaust (upgrade from stock) without removing the aluminum pan?
