Old 02-18-2020, 04:12 AM   #3
1998 Boxster Silver/Red
Nice work. I'm assuming you had to transfer the engine from the motorcycle jack to the furniture dolly in order to get the engine closer to the ground to have the clearance to slide it out? If that's the case, might I suggest an engine hoist and use it to raise the back of the car to give you enough clearance that way? Once the engine is out the back will be a lot lighter, so weight isn't a concern. I just can't recommend a good lift point, having never done a Porsche engine swap.
If necessary, you can use 4X4 blocks on top of the Quick Jack once you raised the back of the car, so you can get the engine hoist out of your way.
I've done this to raise Subarus enough to slide the tranny out.
That last line is pure gold. Pure gold.
1998 Porsche Boxster
