Old 09-28-2006, 02:44 PM   #1
Top will not go up
Top worked fine and then suddenly would not go up. The windows still go up and down and the fuse for the top seems fine. I don't hear anything when I press the top up button. Any one have ideas on possible issues or fixes?
amyandcarlos is offline   Reply With Quote
Old 09-29-2006, 06:00 AM   #2
Send a message via AIM to Travis
You by any chance ever buy the little red clip?
Travis is offline   Reply With Quote
Old 09-29-2006, 06:15 AM   #3
Is your parking brake engaged?
denverpete is offline   Reply With Quote
Old 09-29-2006, 07:09 AM   #4
Yes, parking brake is engaged. What's the little red clip?
Old 09-29-2006, 08:21 AM   #5
When you release the latch to lower the top there is a micro-switch in there that signals the top controller that the latch is released. Yours might be stuck so the controller thinks the top is already up. Use your finger to wiggle the switch. This might be your problem. The windows work because they also think the top is up.
The little red clip fools the controller into thinking that the top is up so you can arm the alarm system with the top down.
Good luck.
derb
derb is offline   Reply With Quote
Old 09-29-2006, 09:55 AM   #6
I had the same thing happen. I had the parking brake pulled up and the top would still not go, I noticed that the parking brake light was not on, I worked the brake handle up and down, still no light, I jiggle the handle side to side and the light came on, as soon as it did I was able to put the top up.
johne4 is offline   Reply With Quote
Old 09-29-2006, 10:47 AM   #7
Thanks for the excellent suggestions. I'll give them a shot. Have had to leave the car at home for the past few weeks and I really want to enjoy the fall before putting the car away for the winter.
Old 10-02-2006, 06:11 AM   #8
It was the parking break. Moved it quickly side to side and up and down. Didn't work. Finally lifted half way up and down about 12 times and the sensor engaged. Thanks for the advice.
