Old 02-19-2019, 04:36 PM   #1
Question Bubble under a gauge face 1999
All,
N00b here and trying to purchase my first Boxster. This 1999 I'm about to pull the trigger on has one tiny, odd flaw....It has a few bubbles on a speedometer face. A) Has anyone ever seen this? B) Carfax is perfect...what might cause it other than Florida heat? and lastly C) ideas on installing a new face?
Thanks everyone! Hope to join you all in ownership soon!
wsmcdowall is offline   Reply With Quote
Old 02-19-2019, 05:29 PM   #2
Those are the stick-on gauge faces that someone added.
Fix by removing them (gauge faces will be black underneath) or buying a used cluster to swap faces with if you prefer the silver/white style.
BTW, I see bubbles on all 3.
Old 02-20-2019, 03:27 PM   #3
Thanks for that! I'm not a fan of white anyway. At the risk of sounding helpless, I haven't been able to find a thread on adding or removing gauge faces. The whole cluster...yes. but not opening up the gauge. Are you aware of any how to's in that? Thanks again!
Old 02-20-2019, 04:27 PM   #4
gman1113's Avatar
Check youtube under 986 gauge cluster light replacement and you will find quite a bit.
gman1113 is offline   Reply With Quote
Old 02-20-2019, 06:21 PM   #5
KevinH1990's Avatar
Check out this post on Rennlist: https://rennlist.com/forums/boxster-and-boxster-s-986-forum/915925-programming-a-996-cluster-to-work-in-a-986-a.html
It contains the instructions I posted for reprogramming a 996 cluster. It also has instructions for disassembling the cluster. This article has some information on removing the cluster from the car:
https://www.pelicanparts.com/techarticles/Boxster_Tech/90-ELEC-996_Cluster/90-ELEC-996_Cluster.htm
KevinH1990 is offline   Reply With Quote
Old 02-20-2019, 06:50 PM   #6
It's funny the difference on personal tastes..
My 987 had White faced gauges and I really like them, and now my new (to me 981) has black face gauges and I am trying to find a way to swap the black face gauges for the white ones, but I have not find them yet, and also don't have the courage to remove the cluster fearing screwing something else while doing it.. :-(
Tags
gauge bubble speedometer
