Old 01-06-2019, 04:53 PM   #1
Boxster piston ring end gaps?
Hi All,
I`m wondering if i should buy new rings for the pistons. Not sure if this has ever been released by Porsche, does anyone know the end gap tolerance values for the 2.5L engine?
Homeoboxter is online now   Reply With Quote
Old 01-07-2019, 10:27 AM   #2
Generic answer.
Is there pressure buildup from the engine case breather, if not, rings are probably fine.
If the car is for high RPM, a slightly larger gap is ok as very little gas/air gets through the gap a such a short time.
Hasting Rings says 0.014 " per inch of bore.
I'm sure there will be after market rings for sale. Most ring widths today are roughly the same for similar size pistons. I haven't stripped a 986 motor but I presume they are nikasiled, so get compatible rings. Ie not for cast iron.
I have a 2.7 motor in the shed just waiting for some spare time to give it a full overhaul.
marsheng is offline   Reply With Quote
Old 01-07-2019, 10:49 AM   #3
Originally Posted by marsheng View Post
Generic answer.
Thanks for the answer. Unfortunately I know nothing about the pressure buildup bc I`ve never seen this engine run. I looked at a Haynes manual for my SAAB 900, based on that values the second ring is out of spec (SAAB uses Mahle pistons and rings as well, the bores are larger though, so I don`t know how accurate that is for a Porsche). Based on what you are saying it really depends on the bore size so it still might be good, I`ll check that out. My worry is mostly about the side rails for the oil ring, if I place them into the bore I can see through the ring and the bore.
Interestingly, you can buy aftermarket rings for all the other engines but not for the 2.5L. For my car the only option I found is to buy the originals, that cost around 2K so it`s out of the equation. I did some research and found that certain BMW rings are the same in size, I`m not sure those are good for Nicasil though..
Old 01-07-2019, 04:25 PM   #4
...Hasting Rings says 0.014 " per inch of bore...
Are you sure they don't say 0.004" per inch of bore? I think 0.014" would be the total end gap
__________________________
'58 356A coupe, just a driver
356Guy is offline   Reply With Quote
Old 01-07-2019, 11:44 PM   #5
Sorry you are correct, from the web Example: 4" (bore) x .0035 = .0 14 minimum gap. I work in mm so I didn't click that .014 was wrong figure.
I understand the 2.5 and 2.7 are basically the same motor. The 2.7 has a 6 mm longer stroke and the pistons are 3mm lower to fit.
My guess is the rings are the same if you can get 2.7s.
I'm sure there are aftermarket ones available for a few $100. Rings aren't rocket science.
Old 01-08-2019, 08:26 AM   #6
I`m not sure about the bore, the ring sets for the 2.7 are listed as 86.5 mm standard size. In my 2.5 I measured roughly 85 mm. But here for instance they claim the two engines are the same bore-wise:
https://www.auto-data.net/en/porsche-boxster-986-2.7-boxter-24v-228hp-6710
I`ll check what the manual says about this.
Old 01-08-2019, 08:34 AM   #7
BYprodriver's Avatar
Generic answer.
There is no nikasil in any 986 engine.
Old 01-13-2019, 08:02 PM   #8
Thanks for elaborating on that!
Old 01-13-2019, 08:06 PM   #9
Yes, the bore size both for the 2.7 and the 2.5 should be 85.5 mm, so rings listed for the 2.7L should be ok for the 2.5L, unless I`m missing something else.
Old 01-14-2019, 07:44 AM   #10
You should measure the cylinder bore's for wear, if they are worn beyond spec you should probably reinstall the original conforming rings in their original positions.
Old 01-14-2019, 10:40 AM   #11
Well, I don`t know the specs and I don`t have precise tools to measure the wear. The bores show no sign of wear by feel and the ring gaps do not change much when I slide the ring all the way down the bore, and there`s no difference if I place the ring to the top of the bore (the area that the ring normally does not reach) vs. if I slide it down. So I assume the wear is not substantial. I think the compression rings could be reused, my worry is about the oil rings, the side rails seem deteriorated, I can see through between the cylinder wall and the side rail when I place them into the bore.
Old 01-14-2019, 12:15 PM   #12
Who's askin'?
maytag's Avatar
Ohhh.... i'd probably back the bus up abit, if I were you. At least lay on the brake some...
If you're trying to do this even partially "right", you shouldn't be letting $100 worth of snap gauges and a caliper stop you. Take your time, do it right. You'll be glad you did.
Old 01-14-2019, 02:41 PM   #13
I do have a caliper and snap gauges, but those are useless to measure cylinder wear. For that you need a bore gauge, and you are right, they are actually much cheaper than I remembered, so I might go ahead and invest into buying one or just take the cases to a machine shop and get them measured. Still, I don`t know the tolerance values for the bore, not even sure if they were released by Porsche.
Old 01-14-2019, 04:22 PM   #14
This would do it, for sure no machine shop would measure the wear and ovality for me for this much:
https://www.amazon.com/Blesiya-50-160mm-Cylinder-Internal-Measuring/dp/B07K59JPYH/ref=sr_1_8?s=industrial&ie=UTF8&qid=1547515233&sr=1-8&keywords=bore+gauge+metric
Old 01-21-2019, 07:08 PM   #15
I still don`t know if the 2.5L and 2.7L piston rings are interchangable. Based on the dimensions (bore size and thickness) they should be identical. However, the sellers say the 2.7L rings won`t fit my 2.5L engine based on the catalog. Am I still missing something here? I already posted some info about the ring end gap measurements in my show&tell gallery and asked the same question there: http://986forum.com/forums/show-tell-gallery/73917-blue-boxster-resurrection-project.html
Perhaps more people read this thread and there`s somebody out there who has seen both of these engines apart and know the answer? Thanks!
Old 01-21-2019, 08:48 PM   #16
Dial the dealer?
Post up on Rennlist?
Otto
2003 Boxster S
1939 Ford DeLuxe Coupe w/392 Hemi
1984 Suby Vanagon Westfalia
Ottomotion is offline   Reply With Quote
Old 01-22-2019, 02:21 AM   #17
The ring gap will seldom change down the bore. The ring wears and opens up the gap. If there is wear in the bore, you will feel a lip just above where the ring stops at the top. No step, bore ok.
Old 01-22-2019, 10:26 AM   #18
Originally Posted by Ottomotion View Post
Dial the dealer?
Thanks Otto, the dealer is gonna tell me what the catalog says. I can try Rennlist, but mostly members there and here overlap, don`t they?
Old 01-22-2019, 10:36 AM   #19
Yeah, I checked that, I think the bores are fine, there`s no lip. It`s possible though that there`s some ovality, and the wear may be different along the bore due to the different piston speeds at different heights. So I`ll measure this just in case. BYprodriver also had a fair point when suggested that if the wear is substantial I may have a better seal with the original rings in the same position than with new ones. But most likely it`ll be fine with a fresh ring set once I find one. I think I`ll just go ahead and order a set for the 2.7 and send it back if it doesn`t fit, but I doubt that.
Old 01-22-2019, 01:00 PM   #20
Check for 996 103 033 02
Mahle piston ring kit Mahle 504 40 N0
EAN 4009026929575
Contains:
Mahle 63504, Rechteckring, Nitriert, Heigth 1,2 mm
Mahle 63745, Nasenminutenring, Heigth 1,5 mm
Mahle 65959, Ölabstreifring (mehrteilig), Nitriert, Height 2,0 mm
https://catalog.mahle-aftermarket.com/eu/product.xhtml?eid=1195707#divider
Fits:
M 96.20, 85,50 Ø, 2.480 ccm
M 96.25, 85,50 Ø, 2.687 ccm
M 96.22, 85,50 Ø, 2.687 ccm
M 97.20, 85,50 Ø, 2.687 ccm
M 96.23, 85,50 Ø, 2.687 ccm
You'll find infos about correct gap in the workshop manual.
There are also piston ring sets for overbore pistons available:
Mahle 504 40 N1
Mahle 504 40 N2
Regards from Germany,
Markus
