Old 05-30-2018, 10:36 AM   #1
Central Locking
Right guys you helped me out big time with my last problem and now onto the next... Central locking stopped working put new batteries in and hey it worked for at least a couple of days now its hit and miss as to whether it will open the doors will not open trunk and frunk...the floor behind passenger seat is dry and the light on the fob seems as bright as when we changed the batteries....any ideas ?
Fungirl is offline   Reply With Quote
Old 05-30-2018, 11:13 AM   #2
http://986forum.com/forums/diy-project-guides/66307-key-transmitter-repair-new-switch-didnt-fix.html
Old 05-30-2018, 11:43 AM   #3
Do the power windows, and convertible top still work? Interior lights? Do the locks operate from the control panel?
If not, check the C3 fuse for corrosion or failure.
bkieffer is offline   Reply With Quote
Old 05-30-2018, 12:58 PM   #4
central locking
everything works fine ..what do you mean exactly by control panel ?
Old 05-30-2018, 01:05 PM   #5
Does the car lock/unlock when you press the button up near the radio?
Old 05-31-2018, 06:35 AM   #6
yes it does
Old 05-31-2018, 10:49 AM   #7
Old 05-31-2018, 11:42 AM   #8
central locking
is there anyone in the UK that repairs keyfobs without having to go to a dealership ?
Old 06-01-2018, 07:12 AM   #9
p3230's Avatar
Go to a shop that repairs electronics it 's probably just a bit of soldering that's needed on the contacts. If that don't work then you will probably have to buy a new key at the dealer. The dealers are not that bad here at least I get all my service done there. Good luck.
Frank
p3230 is offline   Reply With Quote
Old 06-01-2018, 09:54 AM   #10
husker boxster's Avatar
There is a button on your center stack horseshoe that has a picture of a key on it. If you push this button, it should lock the car.
1989 928 S4 5 spd - black
